914-6 setting timing, How do you get to it? |
bfrymire |
Sep 26 2012, 06:54 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
This may seem stupid.. But, I went to check the timing, and I can't get to it. The timing marks are right up against the firewall. So, is there some trick to it? And, I hope you don't have to crawl under a running car to get to it...
-- brett |
mskala |
Sep 26 2012, 08:23 PM
R Group: Members Posts: 1,928 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I don't know of any early engines that would spec 38 degrees. The 911T/914-6 used 35, but all the others were lower. You will need to really find out what the cams are, both to figure out the best advance curve as well as to find out if the guy timed the cams properly. There are folks on the Pelican 911 board that will be able to advise you if you can determine what the parts are in your engine.
bfrymire |
Sep 26 2012, 11:31 PM
Thanks. I will try and determine which cam I have. -- brett I don't know of any early engines that would spec 38 degrees. The 911T/914-6 used 35, but all the others were lower. You will need to really find out what the cams are, both to figure out the best advance curve as well as to find out if the guy timed the cams properly. There are folks on the Pelican 911 board that will be able to advise you if you can determine what the parts are in your engine. |
Lo-Fi Version | Time is now: 15th January 2025 - 05:58 AM |
