Heater Hole Grommet |
pcar916 |
Sep 27 2012, 11:13 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Does anyone know of a good grommet material or better yet, a nearly exact size grommet for these two heater hose holes in the front trunk. I just covered mine with tape because... well I just did. But I want to put a real rubber plug there and route a few wires through them as needed.
Attached image(s) |
gothspeed |
Sep 27 2012, 11:30 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
This is what you are looking for (IMG:style_emoticons/default/smile.gif) ...... If these guys do not have the size you need, just google "closed rubber grommets" ......... you can then punch or cut the size hole you need for your wires through the webbing.
http://www.ebay.com/itm/2-x-Rubber-Grommet...m-/160519544814 These might work too: http://www.anythingtruck.com/Merchant2/mer...amp;Screen=PROD Attached thumbnail(s) |
Lo-Fi Version | Time is now: 15th January 2025 - 04:28 AM |
