914-6 setting timing, How do you get to it? |
bfrymire |
Sep 26 2012, 06:54 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
This may seem stupid.. But, I went to check the timing, and I can't get to it. The timing marks are right up against the firewall. So, is there some trick to it? And, I hope you don't have to crawl under a running car to get to it...
-- brett |
GeorgeRud |
Sep 27 2012, 09:54 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
When I did the conversion on my car, I initially used a cup-type flywheel with the 901 transmission, and the engraved marks on the flywheel were not lined up with the crank pulley. Obviously, there is a difference in the way the crankshafts key the flywheel position between the original 2.0 engine and the 2.7.
Use the crankshaft pulley marks and some whiteout (it seems to show up best IMHO) to make the corresponding marks on the flywheel for TDC and 35 BTDC. |
Lo-Fi Version | Time is now: 15th January 2025 - 05:57 AM |
