No Power to Fuel Pump ? |
kbrunk1 |
Sep 28 2012, 11:02 AM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
OK - Still on blocks.
Moved fuel pump to under tank. I am a pretty good sparky and moved the "fuel pump plug" with ample wire size to extend it to the front under the tank. I soldered it after cutting the "electric plug" from tne back to the front and used lots of shink wrap. Tanks is back in with 1.5 gallons of fuel. I am 99.9 certain it is not a broken wire from the engine bay to under the tank to pump. I check continuity on all fuses under the steering wheel. I electric drill wire brushed the brown grounds by the heater fan and circuit board at that point. Hooked up test 12 volt light on "electric plug" Light flashes when you turn on the key and then the light goes out and you hear a click.....?? Any help here? Not sure here.....Help! |
underthetire |
Sep 28 2012, 11:19 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Fwiw the fuel pump fuse is on the relay board, along with the fuel pump relay.
Lo-Fi Version | Time is now: 15th January 2025 - 03:19 AM |
