Patterned drop in RPMs when idling |
rjames |
Dec 9 2011, 03:06 PM
I'm made of metal Group: Members Posts: 4,163 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
My car idles steady when cold, but after warming up a bit the idle will drop every other second from 900 to ~600. *Sometimes* when the engine is warmed up this doesn't happen. Additionly the volt meeter also drops in unison sometimes (or at least it did today). I haven't measured voltage at the battery while this is happening yet since I only noticed the voltage drop this morning on the way in to work.
It's been doing this since I've owned it for the last 6+ years. If it was a vacuum leak I would expect the RPMs to go up, not down, right? I've done a lot of work to this car, including: replacing all hoses (vacuum and fuel) replaced fuel pump, set fuel pressure, new battery, replaced the relay board new voltage regulator. new plugs, wires, set timing and replaced the points. new injector new injector o-rings. plus other things I'm not remembering at the moment. All of the above work was not done to fix the idle issue, but to solve other issues or as routine maintenance. None of them had any effect on the idle. Car runs good and strong, otherwise. Any ideas of what I should check to remedy this? |
slu234 |
Dec 9 2011, 07:34 PM
Member Group: Members Posts: 57 Joined: 20-January 09 From: Staunton, VA Member No.: 9,949 Region Association: MidAtlantic Region |
You need to make sure your valve adjustment is spot on. Mine was hunting as well. I went through the normal checks (vacuum leaks, TPS setting at idle, fuel pressure) but the it did not go away until my valves were adjusted properly. I found that a few were too loose.
It seems to make sense (and some of the more experienced mechanics could hopefully verify this) that if you change the valve gap you will change the vacuum signal that the MPS sees. I guess as the engine warms up the valve gaps change as well and can impact things more. Record your valve gaps before and after. Brian |
rjames |
Dec 10 2011, 11:37 AM
You need to make sure your valve adjustment is spot on. Mine was hunting as well. I went through the normal checks (vacuum leaks, TPS setting at idle, fuel pressure) but the it did not go away until my valves were adjusted properly. I found that a few were too loose. It seems to make sense (and some of the more experienced mechanics could hopefully verify this) that if you change the valve gap you will change the vacuum signal that the MPS sees. I guess as the engine warms up the valve gaps change as well and can impact things more. Record your valve gaps before and after. Brian Good suggestion, but Ive done two valve adjustments without it changing things. I have hydro lifters, btw. |
rjames |
Oct 2 2012, 11:48 AM
Reviving this thread I started a long while back because I still haven't been able to fix the issue. Would love some additional input.
Scenario is that when at idle, there is a patterned RPM drop of ~300, sometimes more, in a patterned manner. The drop also happens if I rev and hold at higher RPMs, although the drop is much less. Less likely to happen if engine is cold. When coming to a stop after driving and putting the car in neutral, the drop in RPMs can be enough that it feels like the engine may stall, although that's never happened. This has been going on as long as I've owned the car (6+ years) and continues after verifying valve lash (hydro lifters) and full tuneup (plugs, wires, timing, dwell, replacing points, etc). Someone suggested the TPS, but if it happens at higher RPMs, doesn't that make the TPM a less likely candidate? |
Lo-Fi Version | Time is now: 6th January 2025 - 04:43 PM |
