Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Andyrew |
Oct 6 2012, 10:22 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
What manifold did you use? The VW one for the transverse engines?
Engines are pretty low in vibrations so you should be OK, If you used the A/C it might be a bit shaky. Where in the trunk do you have to make room? Enjoying the progress!! |
Mike Bellis |
Oct 6 2012, 10:29 PM
What manifold did you use? The VW one for the transverse engines? Engines are pretty low in vibrations so you should be OK, If you used the A/C it might be a bit shaky. Where in the trunk do you have to make room? Enjoying the progress!! I picked up an OBX (don't laugh), It's the only one I could find that would work for under $500. It actually fits nice and the quality is good. Believe me I was worried! Its for a transverse engine setup. The funky angle on the stock manifold just would not work right. I have to make a hump just like some of the Subie guys do. I will used my roll cage as the corner and just box in around it.. I need to make the targa top fit. That is a priority! |
Lo-Fi Version | Time is now: 26th November 2024 - 03:37 AM |
