Sheared key in fan hub. |
Jesco Reient |
Oct 7 2012, 10:00 PM
Member Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest |
So I was trying to change the seal on the fan Hub, Big leak, when tring to remove the fan hub from the crank it required a puller and an indordinate amount of pressure to break free. Once it had broken free I found that the crank keyway had sheared and was in two pieces. This had happened prior to our buying the car but is one more thing that has shown up during the Tune-Up (IMG:style_emoticons/default/headbang.gif) and leak fix that keeps growing with leaps and bounds (IMG:style_emoticons/default/chair.gif) . any Ideas on cause?
infraredcalvin |
Oct 7 2012, 10:25 PM
Distracted Member Group: Members Posts: 1,552 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Are you taking about the woodruff key insert on the end of the crank? Can pick a new one up at local auto parts store. As for cause, stress and cheap material???
Lo-Fi Version | Time is now: 26th September 2024 - 05:29 PM |
