scott_in_nh |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States ![]() |
So a couple of weeks ago I decided it was time to take care of a few projects on my 74 2.0 D-jet.
A PO moved the 3 port fuel pump up front under the steering rack, but never replaced the plastic fuel lines. The fuel pump works ok, but is noisy and doesn’t hold pressure when I shut the car off. The wiring for it was also cobbled – two wires were run through the tunnel and plugged into the original fuel pump plug, but apparently the positive wire failed so another wire was run from the relay board through the interior and to the pump. It was still grounded through the tunnel wire and original pump harness. I installed Tangerine SS fuel lines and replaced all other rubber lines I hadn’t already replaced and now I am installing a 2 port fuel pump and filter in the same location. The layout proved quite challenging, but I think I have a good solution. My question is can’t I just run the positive wire through the tunnel and ground the fuel pump in front? I did a search and some refer to running “wires” (plural) through the tunnel and some talk about running “a wire”. I just want to make sure I’m not overlooking something….. |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
IMO, the fuel pump is too important to be not grounded correctly. I ran heavy gauge wire from the neg post of the battery to the fuel pump area. This wire was then grounded to the body near the fuel pump. Then I ran a small jumper from the new body ground to my fuel pump. It gives me peace of mind having a dedicated ground for my pump, yes it may be overkill.
Lo-Fi Version | Time is now: 26th June 2024 - 03:19 AM |
