stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Ok, so I bought the deck height measurement tools from the group buy.
But I cannot figure out exactly how the OP intended to use the middle plate. I have been trying to measure my deck height accurately for weeks now and I either am not doing it right, or I have a problem. I have the EMW AA cylinders & KB Hypereutectic pistons - brand new. I am measuring with no shims under the cyls. I bolt the holddown tool on two cyls with pistons installed and torque to spec (24 ft-lbs) I set TDC on the cyl I am about to measure with a mag base & dial indicator using the middle of the piston as reference. I then set a VERY straight edge across both cylinders and clamp it down. I then measure the top of the cylinder mating surface down to the very edge of the piston using a dial indicator/depth gauge. I repeat the measurement at least 5 times and average the results. I am getting measurements that vary from .022 to .032 and they can vary by up to .0067 across a single piston (front to rear). (IMG:style_emoticons/default/WTF.gif) (measurements at the same spot are repeateable within less than .001) When we are trying to get these deck heights to match to within a few thousandths, I cannot see how that can be done when the piston can be off by more than 5 thousandths front to rear. Does this mean I have bent rods or misaligned wrist pin bushings? I had the entire rotating assembly balanced, so I would hope they would have caught something bent. I guess my next steps will be to shuffle the pistons around and see if the measurements follow the pistons. If they dont, I might need to move rods. Can all 4 rods be removed & replaced without splitting the case again? Stu |
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,446 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
Are you using the tool I built?
-Aaron |
Lo-Fi Version | Time is now: 13th March 2025 - 05:17 PM |
