> Deck height measurements driving me crazy, Need advice
stugray
post Oct 14 2012, 02:06 PM
Ok, so I bought the deck height measurement tools from the group buy.
But I cannot figure out exactly how the OP intended to use the middle plate.
I have been trying to measure my deck height accurately for weeks now and I either am not doing it right, or I have a problem.
I have the EMW AA cylinders & KB Hypereutectic pistons - brand new.
I am measuring with no shims under the cyls.
I bolt the holddown tool on two cyls with pistons installed and torque to spec (24 ft-lbs)
I set TDC on the cyl I am about to measure with a mag base & dial indicator using the middle of the piston as reference.
I then set a VERY straight edge across both cylinders and clamp it down.
I then measure the top of the cylinder mating surface down to the very edge of the piston using a dial indicator/depth gauge.
I repeat the measurement at least 5 times and average the results.
I am getting measurements that vary from .022 to .032 and they can vary by up to .0067 across a single piston (front to rear). (IMG:style_emoticons/default/WTF.gif)
(measurements at the same spot are repeateable within less than .001)
When we are trying to get these deck heights to match to within a few thousandths, I cannot see how that can be done when the piston can be off by more than 5 thousandths front to rear.
Does this mean I have bent rods or misaligned wrist pin bushings?
I had the entire rotating assembly balanced, so I would hope they would have caught something bent.
I guess my next steps will be to shuffle the pistons around and see if the measurements follow the pistons.
If they dont, I might need to move rods.
Can all 4 rods be removed & replaced without splitting the case again?
Stu
stugray
post Oct 15 2012, 01:42 PM
1- Just curious, why would shims make a difference. They cannot make it any flatter.
2 - Aaron, Yes I am using your tool, but I cannot make sense how to use the plate. So currently I am just using the holddown bars.
3 - McMark - what are the cylinder spigots? You mean what everyone else calls registers? No I did not have anything on the case machined.
When I put a VERY straight edge across the tops of the cylinders, I do not see any gaps where the straight edge touches the cylinder mating surfaces. I assume within .001 flat acroos two cyls.
Stu
stugray   Deck height measurements driving me crazy   Oct 14 2012, 02:06 PM
Vacca Rabite   Shim the base of the cylinders. Don't start m...   Oct 14 2012, 04:28 PM
rick 918-S   Just a guess but sounds like maybe collapsed regis...   Oct 14 2012, 05:46 PM
Valy   Are the rings on? The pistons will rock a bit in ...   Oct 14 2012, 10:26 PM
yeahmag   Are you using the tool I built? -Aaron   Oct 15 2012, 11:11 AM
McMark   Did you have the cylinder spigots machined?   Oct 15 2012, 11:36 AM
stugray   1- Just curious, why would shims make a difference...   Oct 15 2012, 01:42 PM
yeahmag   The plate simply sits on top of the cylinders loca...   Oct 15 2012, 02:15 PM
r_towle   I measure at the side of the piston directly above...   Oct 15 2012, 03:15 PM
yeahmag   Rich, I think you mean above the piston "wri...   Oct 15 2012, 03:24 PM
r_towle   Rich, I think you mean above the piston "wr...   Oct 15 2012, 04:08 PM
Vacca Rabite   When I did mine I measured from the exact center o...   Oct 15 2012, 03:39 PM
stugray   I have all of the rings on and I measure in line w...   Oct 15 2012, 03:40 PM
yeahmag   Do you understand how to use the tool now? If not ...   Oct 15 2012, 03:45 PM
stugray   The .006 difference is across the same piston wi...   Oct 15 2012, 09:19 PM
wndsrfr   [quote name='stugray' date='Oct 15 201...   Oct 16 2012, 11:31 AM
yeahmag   Which direction are you measuring the piston? Acro...   Oct 16 2012, 10:55 AM
r_towle   If those measurements are at the top of the piston...   Oct 16 2012, 12:59 PM
stugray   This is a vintage race engine that is carbed and...   Oct 16 2012, 04:54 PM
bobhasissues   You have mentioned this cam in several of your t...   Oct 17 2012, 08:03 PM
yeahmag   Measure using the slot on the inner edge of each c...   Oct 16 2012, 04:56 PM
stugray   yeahmag, I only see the large difference in side-...   Oct 16 2012, 05:18 PM
yeahmag   That stinks... Sounds like something is messed up.   Oct 16 2012, 05:22 PM
r_towle   Have you tried a simple feeler gauge and a straigh...   Oct 16 2012, 05:25 PM
stugray   Yes and it showed a difference from side to side...   Oct 16 2012, 10:22 PM
Vacca Rabite   Please put up some pictures of what you are doing....   Oct 17 2012, 06:42 AM
Randal   Please put up some pictures of what you are doing...   Dec 25 2012, 10:31 AM
stugray   Bob - I would post a link to Jakes Type-IV store t...   Oct 18 2012, 10:24 AM
Vacca Rabite   Bob - I would post a link to Jakes Type-IV store ...   Oct 18 2012, 12:00 PM
stugray   The cam is a: "Super 9700 Cam Kit", incl...   Oct 20 2012, 08:17 PM
stugray   Ok, got the new tools to do this right, and the re...   Oct 22 2012, 11:16 PM
rick 918-S   What happens of you swap cylinders? I would invest...   Oct 23 2012, 07:03 AM
yeahmag   Flip the plate end for end so the overhang "t...   Oct 23 2012, 08:28 AM
Valy   What is your deck height right now? You should hav...   Oct 23 2012, 01:29 PM
jmalone   Have you measured from the top of the problem pist...   Oct 23 2012, 02:05 PM
stugray   I will do the suggestions above, but for now I rep...   Oct 27 2012, 12:04 PM
Joe Sharp   Pull the crank and lay it on the bench with all th...   Oct 27 2012, 05:00 PM
stugray   Joe, Thanks! but I was hoping to do as many s...   Oct 28 2012, 11:18 AM
wndsrfr   Joe, Thanks! but I was hoping to do as many ...   Oct 28 2012, 04:27 PM
stugray   Not sure what this means. I flipped the #4 Rod an...   Oct 28 2012, 09:36 PM
yeahmag   Did you measure the cylinder height differences wi...   Oct 28 2012, 10:36 PM
stugray   Yes, less than 0.001 between the two. Stu   Oct 29 2012, 07:16 AM
stugray   Bump! So the only things I can find say that ...   Oct 29 2012, 09:29 PM
yeahmag   I would suspect the rods first. You can snake them...   Oct 30 2012, 10:00 AM
r_towle   You need to open up the case and send everything t...   Oct 30 2012, 10:27 AM
brant   I would have a shop check the registers and also f...   Oct 30 2012, 10:37 AM
Valy   Measure the piston travel. If it's as expected...   Oct 30 2012, 10:38 AM
yeahmag   I agree in principal, but there is no reason not t...   Oct 30 2012, 10:41 AM
stugray   I will go over all of the suggestions above but he...   Oct 30 2012, 02:34 PM
r_towle   Crank was balanced at a shop? then its straight. R...   Oct 30 2012, 02:37 PM
yeahmag   Actually, the rods can be in balance but different...   Oct 30 2012, 02:40 PM
r_towle   Actually, the rods can be in balance but differen...   Oct 30 2012, 02:44 PM
yeahmag   Agreed, but the one thing I have taken to heart fr...   Oct 30 2012, 02:46 PM
stugray   I would agree that the MAIN journals would need ...   Oct 30 2012, 04:53 PM
stugray   ok, latest update. I took all four rods off witho...   Nov 3 2012, 09:57 PM
yeahmag   RIMCO or EMS can do it.   Nov 3 2012, 10:57 PM
Valy   You should have measure the piston travel before t...   Nov 4 2012, 10:45 AM
stugray   Ok, talked to a two local machine shops who claim ...   Nov 7 2012, 10:17 PM
McMark   Remember that each case half must have matching re...   Nov 8 2012, 09:58 AM
stugray   Thanks - he said that he would machine all four re...   Nov 8 2012, 12:58 PM
Racer Chris   ... If the #1 & 2 side is perfect, is there a...   Nov 8 2012, 04:20 PM
Harpo   Thanks - he said that he would machine all four r...   Nov 8 2012, 04:33 PM
stugray   David - Sorry, but what is "EMS"? I kno...   Nov 8 2012, 06:28 PM
Dr Evil   EBS, not EMS. Engine Builder's Supply in Spark...   Nov 8 2012, 06:41 PM
RobW   Any news or update?   Dec 25 2012, 06:59 AM
stugray   I had the cases decked and did another measurement...   Dec 25 2012, 01:35 PM
- Lo-Fi Version Time is now: 13th March 2025 - 04:35 PM
