stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Ok, so I bought the deck height measurement tools from the group buy.
But I cannot figure out exactly how the OP intended to use the middle plate. I have been trying to measure my deck height accurately for weeks now and I either am not doing it right, or I have a problem. I have the EMW AA cylinders & KB Hypereutectic pistons - brand new. I am measuring with no shims under the cyls. I bolt the holddown tool on two cyls with pistons installed and torque to spec (24 ft-lbs) I set TDC on the cyl I am about to measure with a mag base & dial indicator using the middle of the piston as reference. I then set a VERY straight edge across both cylinders and clamp it down. I then measure the top of the cylinder mating surface down to the very edge of the piston using a dial indicator/depth gauge. I repeat the measurement at least 5 times and average the results. I am getting measurements that vary from .022 to .032 and they can vary by up to .0067 across a single piston (front to rear). (IMG:style_emoticons/default/WTF.gif) (measurements at the same spot are repeateable within less than .001) When we are trying to get these deck heights to match to within a few thousandths, I cannot see how that can be done when the piston can be off by more than 5 thousandths front to rear. Does this mean I have bent rods or misaligned wrist pin bushings? I had the entire rotating assembly balanced, so I would hope they would have caught something bent. I guess my next steps will be to shuffle the pistons around and see if the measurements follow the pistons. If they dont, I might need to move rods. Can all 4 rods be removed & replaced without splitting the case again? Stu |
stugray |
QUOTE That's a pretty big number for CR. What cam and gas are you planning on using? This is a vintage race engine that is carbed and will race at >5000 ft and run race gas (if required). I have Jakes full race cam package. QUOTE If those measurements are at the top of the piston, directly above both sides of the wrist pin then you need to deck your case. They are measured directly above the ends of the wrist pins. But when I put a straight edge across the tops of the cylinders they appear to be flat to within .001. To get a tipped piston, I can only imagine a bent rod, or a bad wrist pin bushing. I have a local Porsche expert that told me he has found wrist pin bushings installed incorrectly that would give me this symptom. Stu |
Lo-Fi Version | Time is now: 13th March 2025 - 04:51 PM |
