FS Italian Weber 44idf carbs. fresh from A.C.E, SUPER showcase items. incl velosity stacks REDUCTION! |
rhodyguy |
Oct 18 2012, 12:45 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,192 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the HOT ticket. italian castings. 32mm venturis and the appropriate jetting/air correction for a 2056. new throttle stop arms.tall main stack update. flow bench tested and setup. if you BUY these i would not touch the idle air mixture screws, air bypass, or anything else other than idle speed adjustment screws until AFTER you've installed the linkage.
PLEASE buy a Weber book and a syncro device if you're unfamiliar with these carbs. includes: 1. a set (4) of 44mm velosity stacks. they are 2 1/4" tall. 2. a set (4)of the 36mm (as produced) venturis if you think you need more throat. the manifolds went with a dif set of webers and are no longer included. $600+shipping. i realize it seems like a lot of $... or you can pay about the same or MORE for new castings assembled elsewhere, boxed and shipped as is...or you can buy a core set of carbs, rebuild them yourself, chase the demons that are constantly seen in garage threads...or you can have them built by a KNOWN shop like A.C.E and be done with it. you're going to spend the same amount maybe more than i'm asking. NO PAYPAL. cash or a USPS money order only. k Attached thumbnail(s) |
Gint |
Oct 19 2012, 08:29 AM
Mike Ginter Group: Admin Posts: 16,094 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Did you commission Art to do the carbs? If so I would presume that they're setup for a 2056 at sea level, yes? The reason that I ask is that I understand he's pretty good at jetting them for your motor and altitude, conditions, etc... So I'm curious what they were set up for.
Lo-Fi Version | Time is now: 31st October 2024 - 08:20 PM |
