cam for slight upsizing, going to 2056 on a 2 liter and want the right cam |
worn |
Oct 19 2012, 01:06 PM
can't remember Group: Members Posts: 3,372 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The title says it all. I am rebuilding starting with a 2 liter engine - actually a 1,7 case, but 2 liter crank and heads. Need help choosing a cam for Stock FI. I like the stock FI, and perhaps should have stayed with the original displacement, but I want a wee bit more power.
Actually I want a lot more power, but that is why I also have the 3.2 in the background. Advice about cams for a 2056 build and also about oil pumps would be much appreciated. Also, I really do want to not go the carb route. Thanks! |
76-914 |
Oct 19 2012, 03:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,646 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) If your turning hi rpm's, yes dual spgs. otherwise stay single. your keeping the 1.7 rockers, right. you'll need to set your idle adj full lean, also. it will want to idle rich but how many of us sit in traffic or idle for long periods. has a bit of a lope to it. you'll like it. it's a kick in the pants compared to stock.
worn |
Oct 19 2012, 04:30 PM
(IMG:style_emoticons/default/agree.gif) If your turning hi rpm's, yes dual spgs. otherwise stay single. your keeping the 1.7 rockers, right. you'll need to set your idle adj full lean, also. it will want to idle rich but how many of us sit in traffic or idle for long periods. has a bit of a lope to it. you'll like it. it's a kick in the pants compared to stock. I won't be in the high RPMs - I run the stock RPM limiter on the distributor rotor - I think 5500 cuts out. Plus it is a '76, so I think there is an FI rev limit for that year too, but the information on that I find a bit hazy So, a web cam 73? And adding Valy's specs? |
Lo-Fi Version | Time is now: 22nd December 2024 - 12:42 AM |
