> 914World Classifieds Rules
> FS Italian Weber 44idf carbs. fresh from A.C.E, SUPER showcase items. incl velosity stacks REDUCTION!
rhodyguy
post Oct 18 2012, 12:45 PM
the HOT ticket. italian castings. 32mm venturis and the appropriate jetting/air correction for a 2056. new throttle stop arms.tall main stack update. flow bench tested and setup. if you BUY these i would not touch the idle air mixture screws, air bypass, or anything else other than idle speed adjustment screws until AFTER you've installed the linkage.
PLEASE buy a Weber book and a syncro device if you're unfamiliar with these carbs.
includes:
1. a set (4) of 44mm velosity stacks. they are 2 1/4" tall.
2. a set (4)of the 36mm (as produced) venturis if you think you need more throat.
the manifolds went with a dif set of webers and are no longer included.
$600+shipping. i realize it seems like a lot of $... or you can pay about the same or MORE for new castings assembled elsewhere, boxed and shipped as is...or you can buy a core set of carbs, rebuild them yourself, chase the demons that are constantly seen in garage threads...or you can have them built by a KNOWN shop like A.C.E and be done with it. you're going to spend the same amount maybe more than i'm asking. NO PAYPAL. cash or a USPS money order only.
k
rhodyguy
post Oct 20 2012, 08:30 AM
i was told being substancially above 5k it wouldn't be a big issue for shorter durations. they'd be fat WAY up there, say permanently in summit county co. i'd rather be rich @ altitude than lean @ lower elevations.
k
- Lo-Fi Version Time is now: 31st October 2024 - 08:23 PM
