Mr Hydes rust-tastic transformation, IT RUNS !!!! |
MrHyde |
Dec 5 2010, 12:05 PM
Senior Member Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
Soo.. I've posted a few times on here, got my turn signals working fine while I was off with a bugger'd shoulder... (IMG:style_emoticons/default/mad.gif) Now my shoulder is good so its time to dig into this thing... I've now realized that the tar coating the underside of the car was doing a good job of covering up some real big problems.. (IMG:style_emoticons/default/WTF.gif) I have holes in both right and left rear longs, both rockers, front trunk, floors, firewall.. Transmission I'll have to rebuild, but other than leaky pushrod tube and oil cooler seals... the motor runs strong.. I'll post up some pictures, I'm sure you'll all want to see.. (IMG:style_emoticons/default/blink.gif)
Here is a pic after I drove it home... rear wheels arent folding in and only the right door had a tight gap at the top... didnt look tooo bad when I looked at it.. figured some rocker work and I'd have er' back running in the summer... Attached image(s) |
balljoint |
Oct 21 2012, 05:15 PM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
If you have stock springs then the compressor is needed. The heavier aftermarket springs tend to have the opposite problem of not engaging the perch as they are too short at the full jackstand induced droop.
Lo-Fi Version | Time is now: 15th January 2025 - 05:48 AM |
