FS: 1975 914-V8 Bay Area CA, SOLD SOLD SOLD SOLD!!! Thanks |
matthepcat |
Oct 22 2012, 01:53 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I have been dancing around selling to move to another project for about a year. (IMG:style_emoticons/default/idea.gif) Some of you have seen it in person, other on the forum. I have owned this car since 2010, and fixed most of the bad. (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imageshack.us-11125-1350935602.5.jpg) I am starting at 11,500 firm. Engine 1975 Chevy 355 with mild cam, 9:1 compression, smog legal Holly carb & intake (pretty stock and reliable) ~35,000 miles on engine. Early Renegade kit, that the original owner beefed up with additional bracing & engine mount. 901 trans-axle rebuilt by renegade ( 1st gear block out with tall gears) sometime in the 90's. Chassis Whole chassis reinforced,wheel wells, rear strut towers tied together and to the fire-wall, boxed steel reinforced engine compartment, Boxed trailing arms, welded seams in passenger compartment. Original owner spared no expense to make this car solid. ( could easily be set up for track) You can jack the car from one jack point and lift the whole side of the car up and door opens like its flat on the ground. List of what I have done: • Back date bumpers to 70-74 style bumpers. • Converted front suspension to 1989 Carrera Carrera hubs, rebuilt Bilstein inserts, Carrera vented brake rotors, new ball joints, new turbo tie rods, new wheel bearings. • Porsche 944 Turbo brake calipers with PBR pads and steel braided lines, new 19mm master cyl. • Rear 5 lug was converted using 911 hub with new wheel bearings from Eric. • 100MM wheel studs were used all around the car. • HARTMAN 3 piece forged racing wheels with Yokohama track/street tires. • New custom Fluidyne radiator (utilizing a Pantera radiator core) • Custom cut steel front bumper for radiator and new bumper pad from 914rubber.com • Complete Interior rust removal, Oil base prime/paint, sound deadening, new fuse panel and auxiliary fuse panel, speakers and i-pod connect. • Completely refurbished and powder coated pedal assembly with aluminum foot-board • Custom solid aluminum dash • Transmission output shaft from a 915 trans, along with 100MM Porsche 944 CV upgrade, Machined 914 axles. • J.W. Speaker Hi/Low LED fog light/headlights (very high end) • Prosport gauges: Oil pressure, water temp, voltage, Wide-Band O2 & LED back-lit dash gauges(From AL) for improved night visibility. What it needs Windshield wipers stopped working, but I never drive in wet weather and experience showed me Rain-X worked as a cheap solution. No Heater or A/C becuase people will ask. As reliable as it is, I think it would be good to install TBI ( save some $ at the pump) Needs the back pad light installed & wired. It's a driver, not a show car with some paint chips and scratches. It starts every time, even on a cold morning. I can jump in it now and drive anywhere ( if you could afford the gas and have ear plugs!). PM if you are interested. Matt P.S.--Car comes with a weltmeister front swaybar, and a box of extra stuff. Also the car comes with a binder from the owner before me, and most of my receipts. |
matthepcat |
Oct 23 2012, 12:57 PM
Thanks for the compliments guys. I have had a bunch of interest in it from Craigslist.
I may venture onto e-bay and up the price. |
Lo-Fi Version | Time is now: 6th January 2025 - 04:25 PM |
