stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Ok, so I bought the deck height measurement tools from the group buy.
But I cannot figure out exactly how the OP intended to use the middle plate. I have been trying to measure my deck height accurately for weeks now and I either am not doing it right, or I have a problem. I have the EMW AA cylinders & KB Hypereutectic pistons - brand new. I am measuring with no shims under the cyls. I bolt the holddown tool on two cyls with pistons installed and torque to spec (24 ft-lbs) I set TDC on the cyl I am about to measure with a mag base & dial indicator using the middle of the piston as reference. I then set a VERY straight edge across both cylinders and clamp it down. I then measure the top of the cylinder mating surface down to the very edge of the piston using a dial indicator/depth gauge. I repeat the measurement at least 5 times and average the results. I am getting measurements that vary from .022 to .032 and they can vary by up to .0067 across a single piston (front to rear). (IMG:style_emoticons/default/WTF.gif) (measurements at the same spot are repeateable within less than .001) When we are trying to get these deck heights to match to within a few thousandths, I cannot see how that can be done when the piston can be off by more than 5 thousandths front to rear. Does this mean I have bent rods or misaligned wrist pin bushings? I had the entire rotating assembly balanced, so I would hope they would have caught something bent. I guess my next steps will be to shuffle the pistons around and see if the measurements follow the pistons. If they dont, I might need to move rods. Can all 4 rods be removed & replaced without splitting the case again? Stu |
stugray |
I will do the suggestions above, but for now I repeated all of the measurements with the new depth gauge. (again these measurements are all with no shims under the cylinders)
Cyl #1: Average deck height = 35.0 , "tip" of piston front-to-back = 0.0 Cyl #2: Average deck height = 32.75, "tip" of piston front-to-back = 0.5 Cyl #3: Average deck height = 30.75, "tip" of piston front-to-back = 1.5 Cyl #4: Average deck height = 25.5 , "tip" of piston front-to-back = 8.0 I also measured the "tip" of each piston while at BDC as well as TDC and they were all the same BDC=TDC, so I think that rules out a bent crank So it appears that there is something wrong with cyl #4. My next experiment will be to just flip rod #4 upside down and repeat the measurements. That should tell me if my #1 theory is correct: that I have a bent rod or an improperly installed wrist pin bushing. Stu |
Lo-Fi Version | Time is now: 13th March 2025 - 05:17 PM |
