patssle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None ![]() |
I need to get my /6 3.0L oil cooler modified with an AN or NTP fitting. Being that my oil tank is NPT - I would think that putting a 1" NPT fitting on the oil cooler is the way to go. But I see some people say they used -16 AN.
Does it really matter what type of fitting to use for this application? Thanks. |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
I think that most people have been using the -AN fittings. As long as you can make up the required hose, it probably doesn't make a lot of difference as long as the internal dimensions of the fitting don't restrict oil flow.
Lo-Fi Version | Time is now: 26th June 2024 - 05:45 AM |
