sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
904 /aluminum case 901 ZF limited slip.
My buddy had this lying around , it wont work in the 914-901... Well to much time and little cash.... First the drive flange adapters= Done Second bearing sleeve and spacer. zf uses 45 mm bearings, 914 are 50mm and is about 12mm narrower. Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
sixnotfour |
Worked fine, old school .. low horsepower..and had nadella axles.. I am working on the bearing adapters now.
Lo-Fi Version | Time is now: 25th June 2024 - 10:39 PM |
