> Deck height measurements driving me crazy, Need advice
stugray
post Oct 14 2012, 02:06 PM
Ok, so I bought the deck height measurement tools from the group buy.
But I cannot figure out exactly how the OP intended to use the middle plate.
I have been trying to measure my deck height accurately for weeks now and I either am not doing it right, or I have a problem.
I have the EMW AA cylinders & KB Hypereutectic pistons - brand new.
I am measuring with no shims under the cyls.
I bolt the holddown tool on two cyls with pistons installed and torque to spec (24 ft-lbs)
I set TDC on the cyl I am about to measure with a mag base & dial indicator using the middle of the piston as reference.
I then set a VERY straight edge across both cylinders and clamp it down.
I then measure the top of the cylinder mating surface down to the very edge of the piston using a dial indicator/depth gauge.
I repeat the measurement at least 5 times and average the results.
I am getting measurements that vary from .022 to .032 and they can vary by up to .0067 across a single piston (front to rear). (IMG:style_emoticons/default/WTF.gif)
(measurements at the same spot are repeateable within less than .001)
When we are trying to get these deck heights to match to within a few thousandths, I cannot see how that can be done when the piston can be off by more than 5 thousandths front to rear.
Does this mean I have bent rods or misaligned wrist pin bushings?
I had the entire rotating assembly balanced, so I would hope they would have caught something bent.
I guess my next steps will be to shuffle the pistons around and see if the measurements follow the pistons.
If they dont, I might need to move rods.
Can all 4 rods be removed & replaced without splitting the case again?
Stu
Valy
post Oct 30 2012, 10:38 AM
Measure the piston travel. If it's as expected (71mm or whatever crank you have) then it's a rod problem. If it's less or more (probably less in your case) then it's a bad crank.
You may also check for play in the bearings. Rotate the crank so the piston is at bottom and then push the piston in the bore. If it goes further down you may have bad bearings, any of them can be the faulty: pin bushing,rod bearings or main bearings.
stugray   Deck height measurements driving me crazy   Oct 14 2012, 02:06 PM
Vacca Rabite   Shim the base of the cylinders. Don't start m...   Oct 14 2012, 04:28 PM
rick 918-S   Just a guess but sounds like maybe collapsed regis...   Oct 14 2012, 05:46 PM
Valy   Are the rings on? The pistons will rock a bit in ...   Oct 14 2012, 10:26 PM
yeahmag   Are you using the tool I built? -Aaron   Oct 15 2012, 11:11 AM
McMark   Did you have the cylinder spigots machined?   Oct 15 2012, 11:36 AM
stugray   1- Just curious, why would shims make a difference...   Oct 15 2012, 01:42 PM
yeahmag   The plate simply sits on top of the cylinders loca...   Oct 15 2012, 02:15 PM
r_towle   I measure at the side of the piston directly above...   Oct 15 2012, 03:15 PM
yeahmag   Rich, I think you mean above the piston "wri...   Oct 15 2012, 03:24 PM
r_towle   Rich, I think you mean above the piston "wr...   Oct 15 2012, 04:08 PM
Vacca Rabite   When I did mine I measured from the exact center o...   Oct 15 2012, 03:39 PM
stugray   I have all of the rings on and I measure in line w...   Oct 15 2012, 03:40 PM
yeahmag   Do you understand how to use the tool now? If not ...   Oct 15 2012, 03:45 PM
stugray   The .006 difference is across the same piston wi...   Oct 15 2012, 09:19 PM
wndsrfr   [quote name='stugray' date='Oct 15 201...   Oct 16 2012, 11:31 AM
yeahmag   Which direction are you measuring the piston? Acro...   Oct 16 2012, 10:55 AM
r_towle   If those measurements are at the top of the piston...   Oct 16 2012, 12:59 PM
stugray   This is a vintage race engine that is carbed and...   Oct 16 2012, 04:54 PM
bobhasissues   You have mentioned this cam in several of your t...   Oct 17 2012, 08:03 PM
yeahmag   Measure using the slot on the inner edge of each c...   Oct 16 2012, 04:56 PM
stugray   yeahmag, I only see the large difference in side-...   Oct 16 2012, 05:18 PM
yeahmag   That stinks... Sounds like something is messed up.   Oct 16 2012, 05:22 PM
r_towle   Have you tried a simple feeler gauge and a straigh...   Oct 16 2012, 05:25 PM
stugray   Yes and it showed a difference from side to side...   Oct 16 2012, 10:22 PM
Vacca Rabite   Please put up some pictures of what you are doing....   Oct 17 2012, 06:42 AM
Randal   Please put up some pictures of what you are doing...   Dec 25 2012, 10:31 AM
stugray   Bob - I would post a link to Jakes Type-IV store t...   Oct 18 2012, 10:24 AM
Vacca Rabite   Bob - I would post a link to Jakes Type-IV store ...   Oct 18 2012, 12:00 PM
stugray   The cam is a: "Super 9700 Cam Kit", incl...   Oct 20 2012, 08:17 PM
stugray   Ok, got the new tools to do this right, and the re...   Oct 22 2012, 11:16 PM
rick 918-S   What happens of you swap cylinders? I would invest...   Oct 23 2012, 07:03 AM
yeahmag   Flip the plate end for end so the overhang "t...   Oct 23 2012, 08:28 AM
Valy   What is your deck height right now? You should hav...   Oct 23 2012, 01:29 PM
jmalone   Have you measured from the top of the problem pist...   Oct 23 2012, 02:05 PM
stugray   I will do the suggestions above, but for now I rep...   Oct 27 2012, 12:04 PM
Joe Sharp   Pull the crank and lay it on the bench with all th...   Oct 27 2012, 05:00 PM
stugray   Joe, Thanks! but I was hoping to do as many s...   Oct 28 2012, 11:18 AM
wndsrfr   Joe, Thanks! but I was hoping to do as many ...   Oct 28 2012, 04:27 PM
stugray   Not sure what this means. I flipped the #4 Rod an...   Oct 28 2012, 09:36 PM
yeahmag   Did you measure the cylinder height differences wi...   Oct 28 2012, 10:36 PM
stugray   Yes, less than 0.001 between the two. Stu   Oct 29 2012, 07:16 AM
stugray   Bump! So the only things I can find say that ...   Oct 29 2012, 09:29 PM
yeahmag   I would suspect the rods first. You can snake them...   Oct 30 2012, 10:00 AM
r_towle   You need to open up the case and send everything t...   Oct 30 2012, 10:27 AM
brant   I would have a shop check the registers and also f...   Oct 30 2012, 10:37 AM
Valy   Measure the piston travel. If it's as expected...   Oct 30 2012, 10:38 AM
yeahmag   I agree in principal, but there is no reason not t...   Oct 30 2012, 10:41 AM
stugray   I will go over all of the suggestions above but he...   Oct 30 2012, 02:34 PM
r_towle   Crank was balanced at a shop? then its straight. R...   Oct 30 2012, 02:37 PM
yeahmag   Actually, the rods can be in balance but different...   Oct 30 2012, 02:40 PM
r_towle   Actually, the rods can be in balance but differen...   Oct 30 2012, 02:44 PM
yeahmag   Agreed, but the one thing I have taken to heart fr...   Oct 30 2012, 02:46 PM
stugray   I would agree that the MAIN journals would need ...   Oct 30 2012, 04:53 PM
stugray   ok, latest update. I took all four rods off witho...   Nov 3 2012, 09:57 PM
yeahmag   RIMCO or EMS can do it.   Nov 3 2012, 10:57 PM
Valy   You should have measure the piston travel before t...   Nov 4 2012, 10:45 AM
stugray   Ok, talked to a two local machine shops who claim ...   Nov 7 2012, 10:17 PM
McMark   Remember that each case half must have matching re...   Nov 8 2012, 09:58 AM
stugray   Thanks - he said that he would machine all four re...   Nov 8 2012, 12:58 PM
Racer Chris   ... If the #1 & 2 side is perfect, is there a...   Nov 8 2012, 04:20 PM
Harpo   Thanks - he said that he would machine all four r...   Nov 8 2012, 04:33 PM
stugray   David - Sorry, but what is "EMS"? I kno...   Nov 8 2012, 06:28 PM
Dr Evil   EBS, not EMS. Engine Builder's Supply in Spark...   Nov 8 2012, 06:41 PM
RobW   Any news or update?   Dec 25 2012, 06:59 AM
stugray   I had the cases decked and did another measurement...   Dec 25 2012, 01:35 PM
20 User(s) are reading this topic (20 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 13th March 2025 - 05:27 PM
