Rear wheel bearing replacement, Parts needed? |
JawjaPorsche |
Nov 14 2012, 01:12 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
My right rear bearing is making noises. I called my mechanic and he said to get parts and he would install it.
I am looking at the exploded view of rear axle. (See below) When I order parts, do I just need the Bearing #28? Is there a race for the control arm because I don't see one? Does he need to remove CV axle and tap out the bearing from the inside? Thank you in advance for your help. Attached thumbnail(s) |
matthepcat |
Nov 14 2012, 03:24 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
You will also need a freezer and time to let it freeze for two days, or dry ice. You might also want a torch.
JawjaPorsche |
Nov 14 2012, 04:25 PM
I read about the freezer trick earlier and was planning to do. Getting bearing tomorrow and will freeze until Monday! (IMG:style_emoticons/default/beerchug.gif)
You will also need a freezer and time to let it freeze for two days, or dry ice. You might also want a torch. |
Lo-Fi Version | Time is now: 16th September 2024 - 01:42 PM |
