Rear wheel bearing replacement, Parts needed? |
JawjaPorsche |
Nov 14 2012, 01:12 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
My right rear bearing is making noises. I called my mechanic and he said to get parts and he would install it.
I am looking at the exploded view of rear axle. (See below) When I order parts, do I just need the Bearing #28? Is there a race for the control arm because I don't see one? Does he need to remove CV axle and tap out the bearing from the inside? Thank you in advance for your help. Attached thumbnail(s) |
Jeffs9146 |
Nov 14 2012, 04:36 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
If your mechanic is doing the work then he will need to freeze it because it needs to come out of the freezer and directly into the trailing arm before it warms and expands!
I leave a 60w light on the trailing arm for a few hours before and coat it with a light coat of grease. Then I put the frozen bearing in and most of the time it slides in like butter!! But if you wait to long it will stick and you have to finish by pressing it the rest of the way in! PS: It is way easier to do it on the bench than on the car! |
Lo-Fi Version | Time is now: 16th September 2024 - 01:29 PM |
