Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Here is a build I started tonight. It is going to be pretty special with an LSD and some billet bits. Even though I am not for billet intermediate plates, I still like the look and this customer had been amassing parts for a long time before he heard my thoughts on them. No biggie. They take good pics (IMG:style_emoticons/default/smile.gif)
What you see here is a 930 pinion bearing, the rare and NLA steel caged input bearing, and a billet plate. Attached image(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
My mechanic had a number of unkind things to say about the brass-caged ones when we did the rebuild. He preferred the steel-caged bearings as well; probably because they were one unit and didn't fall apart as you were trying to install them. (At least, that's the impression that I got from what he was saying.)
--DD |
Dr Evil |
My mechanic had a number of unkind things to say about the brass-caged ones when we did the rebuild. He preferred the steel-caged bearings as well; probably because they were one unit and didn't fall apart as you were trying to install them. (At least, that's the impression that I got from what he was saying.) --DD The cages and balls can fall out, but the balls are captive in the cage. The main thing is that the steel doe snot shatter and the brass shatters very easy. I have seen more than once where a new one broke with minimal effort (not by me, luckily). That is a $200+ bearing that does this. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
My mechanic had a number of unkind things to say about the brass-caged ones when we did the rebuild. He preferred the steel-caged bearings as well; probably because they were one unit and didn't fall apart as you were trying to install them. (At least, that's the impression that I got from what he was saying.) --DD The cages and balls can fall out, but the balls are captive in the cage. The main thing is that the steel doe snot shatter and the brass shatters very easy. I have seen more than once where a new one broke with minimal effort (not by me, luckily). That is a $200+ bearing that does this. I haven't really had a problem with the replacement brass cage bearings over the last 39 years, but I haven't done nearly as many trannies as you have. No comebacks, though, so the bearings must be holding up .............. The Cap'n |
Lo-Fi Version | Time is now: 26th June 2024 - 09:12 AM |
