913B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None ![]() |
So i am on the final leg of my front end rebuild. Is there a sequence to install. Currently the front drop link sway bars are attached to the control arms. The following needs to be install.
1. Torsion bar end caps 2. Attach strut to the ball joint with the wedge bolt 3. Attach the top 3 hex bolts on the strut I know its simple but i woud hate to do it 2x and have to knock out that wedge bolt or something Thanks in advance. Oh if you know any good threads to install/adjust the torsion bars it would appreciated. Sorry search is not my friend |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Ted,
I would attach the strut to the top of the fender. Then put the wedge into the ball joint. Lastly torsion bar end caps. Make sure you index the torsion bar caps when you install them. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:12 AM |
