ITB project, Honda VFR 800 ITBs |
kevin311 |
Aug 17 2012, 11:25 AM
Member Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None |
I've been running Megasquirt II for a while now on my 71 1.7 with the stock D-jet components and it has been running well. But everything is looking tired in the engine bay and I am planning on taking out the engine to clean everything up and install SS fuel lines.
Then I remembered seeing a video youtube with an australian guy reviewing his 914 and he mentioned having GSXR ITBs on his car. Sounds like a fun project to me so I started researching and think I have found an even better solution. The throttle bodies I found are from a 2001 Honda VFR800. The bike is a V4 so the TBs and fuel rails are already split into pairs, and have a linkage that connects both. They have 37mm throats, and came with the throttle position sensor, fuel pressure regulator , injectors and and all the wiring and connectors. Also the brackets on the sides already have a tab for throttle cable. The injectors are high impedance so I wont have to run PWM on Megasquirt anymore and hopefully can get an even finer tune. I'm also thinking about switching the PCs for 96mm, but I think that will wait until later, but you never know this started out as an engine cleaning... The only things I need to figure out are the flow rate of the injectors, where I'm going to hook up the IAT sensor, and will need to build a vacuum plenum. Also these injectors run at 36 psi, can the stock fuel pump handle that or do I need to look for another solution? Here are some pics, check out how close the spacing is for weber manifolds. Please excuse the dirt. I still haven't cleaned them up. This is gonna be fun. (IMG:style_emoticons/default/beerchug.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224315.1.jpg) (IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03555.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224325.2.jpg) (IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03552.jpg) (IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03558.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224346.3.jpg) (IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03559.jpg) |
wndsrfr |
Nov 25 2012, 06:32 PM
Senior Member Group: Members Posts: 1,438 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Super cool looking setup but I'm concerned with your injector flow rate....might be a bit tight with 1.7l displacement vs. 0.8l on the Honda. Do you have a wideband AFR installed to watch for lean running......?
aircooledtechguy |
Nov 25 2012, 10:22 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
Super cool looking setup but I'm concerned with your injector flow rate....might be a bit tight with 1.7l displacement vs. 0.8l on the Honda. Do you have a wideband AFR installed to watch for lean running......? I've been searching in vain for the injector p/n & specs specs for the early VFR800 like this one. But I did come up with the info on the '06-'09 injectors (p/n 16450-MEL-003) which are shared by the CBR1000 of the same vintage. . . They flow 294cc/min @ 43 psi / 315cc/min @ 50 psi (!) which makes them support well over 300hp(!!) TOTALLY overkill for a motorcycle but perfect for a car. If the early injectors flow even remotely close, I doubt you will have ANY problems with running lean. In fact you will have to drastically re-map your VE tables. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 24th November 2024 - 07:38 PM |
