ONTHEGRIND |
Member ![]() ![]() Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None ![]() |
Going to widen the rear flare and repaint looks like a little more work then expected
Attached image(s) ![]() ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
well.
The front part hangs off a flexible area that is for the door hinges and the back is also on a flexible part of the rear panel. Pull on a rear fender and see how much the rear door gap changes. For structure bracing I go from the inner long, just above it where the speakers would be up to the upper seat belt bolt. One large bar will do on each side. Then, given what you are replacing, build a square tube horizontal box inside the car, as low down as you can and once that is in place, weld an X onto that setup to hold the entire chassis square as you remove the rear firewall. |
Lo-Fi Version | Time is now: 28th June 2024 - 04:07 PM |
