shuie |
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 ![]() |
Has anyone ever done a floor pan replacement or other major structural metal replacement with panel bonding adhesives instead of spot & seam welding?
The bond is supposed to be as strong as a proper weld, there would be no worries about overheating and warping the metal, the entire seam would be joined & sealed which should make the tub A LOT stiffer. It would certainly be cheaper than buying a welding rig. I guess the downsides would be that working within the setup time for the adhesives could be difficult and you would need a lot of clamps. Maybe the unibody would be too stiff if every seam was joined like this? My interest in this is academic. This is not something I am planning on trying since I've already welded almost all of my replacement panels in. I do need to use an adhesive to attach a fiberglass piece to my steel hood and I've seen threads on the forums where reputable shops have attached metal flares with adhesives so I thought I would ask about it. I'm sure there is a good reason why I have never seen anyone use the adhesives for something like a floor pan. |
ldsgeek |
Member ![]() ![]() Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None ![]() |
Assemblies have to be designed for this process. It's not simply a case of replacing welding with chemical bonding. As has been mentioned, this usually means larger interfaces with the loads aligned in the best direction for the bonding agent used.
Lo-Fi Version | Time is now: 26th June 2024 - 05:15 AM |
