malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I just finished installing the rear half of my floor pans. Is there a trick to getting the seat hinge mount located in exactly the right location?
The tilt mechanism seems to be the critical factor on this. if the teeth are too tight you get no adjustment. If the teeth are not seated enough, maybe loose some support or even have a slip out issue. |
Socalandy |
Its got to be Yellow!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California ![]() ![]() |
here are some measurements from a parts car. you could also install the Adj. tooth and mock it all up with the seat rails.
Attached thumbnail(s) ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 12:23 AM |
