seat hinge location, new floor pans |
malcolm2 |
Nov 28 2012, 09:35 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I just finished installing the rear half of my floor pans. Is there a trick to getting the seat hinge mount located in exactly the right location?
The tilt mechanism seems to be the critical factor on this. if the teeth are too tight you get no adjustment. If the teeth are not seated enough, maybe loose some support or even have a slip out issue. |
jimkelly |
Nov 28 2012, 12:00 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i would think if you get the comb tacked in - you could use a seat rail as a template for the hinges.
Attached image(s) |
Lo-Fi Version | Time is now: 26th June 2024 - 12:32 AM |
