Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,380 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
My brother has a 74 914 2.0 that's going to get a 83 3.0 SC installed into it.
The engine is going to be run with Weber carbs. I know that some members may have a 3.0 installed in their 914's . The question that I have is what type of ignition source are you using? I've heard the 83 distributor cant be used and need to use an earlier one ? Can a MSD 6AL box, & coil be used instead of the cd box? The engine wire harness what's needed to make this work? Any help would be greatly appreciated. Thanks, Luke |
Luke M |
I was planning on hitting up the guys on the Bird board later today.
The p/o told me I couldn't use the distr because there's no mech advance and to use an early 3.0 unit. I'll do some research hopefully come up with an answer. Thanks |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I was planning on hitting up the guys on the Bird board later today. The p/o told me I couldn't use the distr because there's no mech advance and to use an early 3.0 unit. I'll do some research hopefully come up with an answer. Thanks No mechanical advance? My 79 has both, for webers you would get rid of the vacuum advance and recurve. There is the MSD AL6-2 programmable, you lock out the dizzy and program the curve via computer. USB update so you don't need a laptop. They have had problems with the small cap 2.0-2.7 dizzy's phasing but a 3.0 cap and rotor are larger so maybe it would be OK. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:57 AM |
