Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,380 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
My brother has a 74 914 2.0 that's going to get a 83 3.0 SC installed into it.
The engine is going to be run with Weber carbs. I know that some members may have a 3.0 installed in their 914's . The question that I have is what type of ignition source are you using? I've heard the 83 distributor cant be used and need to use an earlier one ? Can a MSD 6AL box, & coil be used instead of the cd box? The engine wire harness what's needed to make this work? Any help would be greatly appreciated. Thanks, Luke |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Another option is a Megajolt jr EDIS ignition or you can run megasqirt in ignition only (many options including a locked out dizzy/MSD).
Both would give you programmable crankfire ignition. |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,631 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Another option is a Megajolt jr EDIS ignition or you can run megasqirt in ignition only (many options including a locked out dizzy/MSD). Both would give you programmable crankfire ignition. I just saw a friends car with EDIS and Megajolt. It cured his idle problems, allowed him to program in a very quick advance. I was very impressed. I will be going this way with my 240Z. |
Lo-Fi Version | Time is now: 26th June 2024 - 11:03 AM |
