LCOX |
Member ![]() ![]() Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None ![]() |
Can I use a 2.0 crank and rods with a 1.8 case. Thanx! L
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Can I use a 2.0 crank and rods with a 1.8 case. Thanx! L Yes. If you then use OE 94mm pistons and cylinders you have a 2 liter engine. If you use the 1.8 heads, you have what is effectively a VW bus engine (watch the C/R! with those heads!). If you use 96 mm pistons, the ones made for a 2 liter crank, you have a 2056 or something like that. You'll have to be careful about the deck height as the compression ratio goes up as the bore increases. The Cap'n |
Lo-Fi Version | Time is now: 26th June 2024 - 10:53 AM |
