SOT: electrical gurus check in..., how to dim LEDs? |
dlo914 |
Nov 30 2012, 12:45 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
So i've retrofitted some LED rings into my daily driver, but i'm only using the LEDs as the running lights and using the filament bulb when brakes are applied. how would i go about using the LEDs for both running and braking light usage? i know i'm suppose to add a resistor to each positive LED wire, but i'm so confused as to what OHM rating or % etc i'm suppose to use. The guys at two radioshacks were useless.
Here's how they look at the moment: (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-2697-1354257938.1.jpg) |
mr914 |
Nov 30 2012, 03:04 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Temporary, or could be permanent...
Buy a variable resistor/potentiometer Put in circuit and adjust to desired brightness Remove and measure with ohm meter. Go to rat shack and buy resistor of appropriate value |
Lo-Fi Version | Time is now: 25th June 2024 - 08:37 PM |
