lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
A few years ago, when I still raced motorcycles, there were a number of jokers who ran a team called The Army of Darkness. Not Satanists, just troublemakers. They wrote up a series of great technical articles referring esp. to a now dead engine designer named Phil Irving. Irving divulged the following simple formula:
cyl size / (valve_size * lift * pi * valve_count) * ((rpm/2))/60 This gives the mean gas speed through the intake tract, which, when crunched against the stats for a wide variety of bikes they available, turned up the fact that the maximum gas speed for a normally-aspirated engine was about 12.5m/s. Above that gas speed, power always falls off, presumably because at that point, more airflow simply doesn't happen (sonic wall). This means that the formula above can show what the max USEFUL revs will be for given valve sizes and lift. This worked on every bike engine they tried (and a few they didn't, which I did later). Today, with some time to kill, I tried the Type 4. I have a 1.7, so that's what I used. 1679cc, so 419.75cc per cylinder. Valve sizes are 39.33mm, and there's one intake per cylinder. Lift I didn't know for the stock cam, but a troll through some other references suggested it was somewhere between 10-11mm (at the valve, not the cam). I tried the above for 10mm, and BING! max gas speed at 4500rpm is 12.7m/s. 4500rpm is the power peak for a stock 1.7. Looks like this formula works for the Type 4, too. What else can we find out? Well, hp = torque * rpm / 5252. Increase engine speed w/o altering torque and power rises. Problem is, if the engine doesn't breathe at the elevated engine speed, torque drops off, so power drops off. If you can raise the engine speed w/o harming breathing, you'll get more power. Well, with 42mm valves (stock for the 2.0) and the 10mm lift, the power peak only rises to 4700rpm. This suggests only a mild power increase (about 4%). With a cam/rocker combo giving 12mm of lift, however, the power peak rises to 5700rpm (26%). With the cam alone and stock 1.7 valve sizes, the power peak rises to 5300rpm (18%). This suggests that with 2.0 heads and a 12mm lift cam, you can get 100hp out of a 1.7. With just the cam, you can't do better 95. All of this ignores a whole host of other factors, but it's interesting that first order approximations seem to work. It's esp. interesting that Irving wrote this work in 1948, and it still works today. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
it could be just for estimating baseline hp or the minimum it should produce ideally....not maximum power
Lo-Fi Version | Time is now: 25th June 2024 - 10:54 PM |
