jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
i think the one i just installed is a 19.
instead of having 2 male electrical spades on it - it has only one and a rubber nub in center - which does not match up with the 2 that i have on my harness? do i need to get a pressure switch from a 17mm and replace the one on the 19 ??? i also just replaced the brake lines thru tunnel and in engine bay and installed prop valve on passenger side. not pretty but should suffice?? also - is there supposed to be a washer between tha banjo and the mastercylinder or just between banjo and male/female dohickey that holds banjo in place? Attached image(s) ![]() ![]() ![]() ![]() |
jimkelly |
i was gonna check ace for a cap but since i ordered the strainer and the 2 seals, i will just run a short bit of 8mm line and plug it. thanks
and here is the MC on my other car - clearly can see the 2 metal gaskets on either side of the banjo. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 12:35 AM |
