vitaminC |
searching... ![]() Group: Members Posts: 48 Joined: 29-August 10 From: NorCal Member No.: 12,121 Region Association: Northern California ![]() |
Since I was heading down to San Diego yesterday, I stopped by an checked out this yellow '71. With a few exceptions, it's just as clean in person as in the pics. The exceptions being the trunks, as there is a bit of rust in both. The worst is in the rear as seen here:
![]() Nothing penetrated through, but it was a bit gunky. There was just a small amount of surface rust in the pan of the frunk. I've read about tail- and side-shifters, and now understand why the former is best avoided. What's a rough estimate on what it would cost to swap out to a side shifter? Or, maybe it's something you get used to? There was no grinding into any gear, it was just very hard for me to find 1st. However, the engine was able to pull from a stop in 3rd, so I guess that says something good about the motor. Other little nitpicks are that the trim is still not completely installed, and it needs various adjustments (like the windows not sealing against the targa top). The engine was rebuilt out to a 2.0 (not 2056) by Tuttle(?), using the original cases and heads, and the final tuning was done at Benton Performance. Anyone have experience with them? I guess my question is, is there any reason not to buy this car? I think there is some flex in the price. Any good shops in the area that could do an inspection? |
vitaminC |
Thanks for the replies. I get that rust is bad. I also get that I don't want to want to spend $15k for a 'perfect' rust free 914, because at that price I'll take a 911SC instead. However, there must also be some value to having had all the mechanicals refurbished.
I'll check with the seller and see if he has any photos showing the car before it was painted, and perhaps that can provide more clues about the rust situation. |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Thanks for the replies. I get that rust is bad. I also get that I don't want to want to spend $15k for a 'perfect' rust free 914, because at that price I'll take a 911SC instead. However, there must also be some value to having had all the mechanicals refurbished. I'll check with the seller and see if he has any photos showing the car before it was painted, and perhaps that can provide more clues about the rust situation. It could just be a really shitty application of seam sealer. Clearly it it but, is it covering up some shoddy work? Who knows. There is a value to that car and if you could get the seller down in the $5-8K range it might work out. The rest of the car is very clean. Rust is the enemy of the 914. If you see rust on a 914, it is only 30% of what it ACTUALLY has. The rest of the rust is hidden and needs to be found. So show the seller of some "correct" trunks and see if you could talk him down. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:16 AM |
