Very frustrating fuel or motor problem |
hars914 |
Jun 21 2004, 05:41 AM
Member Group: Members Posts: 114 Joined: 6-January 03 Member No.: 94 |
I need help on this problem. It happened out of no where.I have a 71 which just
went thru a 3 year resto. The motor is a 4 cyl. 2.0 built up to 2.4 with weber 40idf carbs and about 1200 miles on the new motor. I was having what seems to be a fuel problem. I would take the car out and after about 15 or 20 min. the motor would start stumbling like it was not getting fuel. It would get worse then start to stall. I removed the gas tank and it was spotless on the inside,I removed the screen and cleaned it, I made sure the line from the tank to the carbs is clear. I installed a new Carter pump,I removed the Holley regulator and ran new -6 lines to the carbs. When I fired it up with the new pump it was pumping about 5 or 6 psi and I noticed it would drop to about 3.5 psi after it would start stumbling. Ther are no kinked lines.What am I missing here. I also removed the carbs and cleaned out all the jets. Could this be motor related? |
SLITS |
Jun 21 2004, 11:13 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Ok, I'll make the assumption that you are not blowing black smoke due to an overrich condition of the float valve sticking and pushing pressurized fuel thru the carbs..........,
1.) Do you have the bakelite insulators between the heads & manifolds? = Avoidance of boiling fuel in the carb bowls. Also some vibration elimination. 2.) The -6 line - Is is the Russel or Aeroquip (rubber) line - Russel deteriorated real quick on the race car and I would never use it again (even if they said they improved their quality) 3.) I'll assume that all the fastners on the manifolds/carbs are secure. Heading toward an intake leak as the metals expand. 4.) With the drop in fuel pressure - to me it would have to be a collapsed/plugged line or the float valves sticking open. Hey, it's all a guess |
Lo-Fi Version | Time is now: 20th October 2024 - 06:27 AM |
