Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
As I mention later in the Thread brad Mayer had mentioned these may be no longer available in the future, that's why I took these on. I'm making these out of a more durable silicone, so these should last longer.
These should be ready to ship in January. Let me know if you need any. Attached thumbnail(s) ![]() |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Mark,
Will the drain tubes allow rust particles to pass ? How large a particle is gonna block the drain ? |
Mikey914 |
Mark, Will the drain tubes allow rust particles to pass ? How large a particle is gonna block the drain ? Depends on how big they are (IMG:style_emoticons/default/smile.gif) I did make the "hole" on the bottom larger and made the corners square to make it harder to collapse. The material is slightly harder durometer. These should be oriented with the widest side against the wind (as Eric has shown), and as it gets blown back the low pressure area that is behind the profile will help suck out water. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:14 PM |
