Snorkel Tube wiring harness GB $28 each, These will be $45 after the GB - GB ends June 16th |
Mikey914 |
Dec 20 2012, 01:28 AM
The rubber man Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
A great part to have if you need one. I was tapped to make these awhile ago, and there looked like there was some interest in doing these. I plan to make them from silicone of a soft enough durometer to allow them to stretch easily. The flanges will be slightly larger to allow for a tighter fit. So there will be some improvements, but look pretty stock. They should be easier to install than stock. I try to make most of my stuff as close to factory as possible where it makes sense, and I think factory had it right as one piece.
Attached thumbnail(s) |
IronHillRestorations |
Dec 29 2012, 02:32 PM
I. I. R. C. Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Does the silicone more stretch than the original? I'm in on the group buy, and I appreciate Mark making these, but I sure to think that a split style is still the way to go. I want to see the 1st guy that pulls all the wires (with connectors) through one of these.
gothspeed |
Dec 29 2012, 03:02 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Does the silicone more stretch than the original? I'm in on the group buy, and I appreciate Mark making these, but I sure to think that a split style is still the way to go. I want to see the 1st guy that pulls all the wires (with connectors) through one of these. +1 ... I agree on the split style. I was thinking of buying an extra one then try and split it, then glue it back together. If that works it will be great, if not then it will be as good as the torn one I have now ... (IMG:style_emoticons/default/popcorn[1].gif) |
Mikey914 |
Dec 31 2012, 02:49 PM
Does the silicone more stretch than the original? I'm in on the group buy, and I appreciate Mark making these, but I sure to think that a split style is still the way to go. I want to see the 1st guy that pulls all the wires (with connectors) through one of these. +1 ... I agree on the split style. I was thinking of buying an extra one then try and split it, then glue it back together. If that works it will be great, if not then it will be as good as the torn one I have now ... (IMG:style_emoticons/default/popcorn[1].gif) The only ones that would have to be glued together are the ones that would be longer. The idea would be to use the center section from one to extend the legnth. It would be slathered in glue and rolled over the end pieces. It just will not pencil out to make the tooling in 2 diferent versions. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:22 AM |
