jdlmodelt |
James D. Lane ![]() ![]() Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region ![]() |
I finally got the ignition and fuel pump hooked up on my 76 2.0 L and the engine cycles between reving and stalling when I hold the pedal down to get a fast idle. What do I need to be checking now?
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
Pinched line, clogged filter, filter on backwards, lines routed wrong (engine bay feed and return swapped). Have you tried putting a pressure gauge on to see what it is? You can pull the line off the cold start valve and hook it up there. 29-30 pounds. Can also check inside your gas tank for crud and a clogged stainer sock. Valves adjusted properly? Timing and dwell correct? Idle air screw on the throttle body, have you tried turning that up? You also have an adjustment on your ECU. Clockwise enriches, counter clockwise leans. That typically has a melted in hashmark for where the factory setting is.
Lo-Fi Version | Time is now: 26th April 2025 - 01:35 AM |
