> 2.0l fuel injected engine surge starve cycle?
jdlmodelt
post Jan 2 2013, 08:20 PM
James D. Lane
I finally got the ignition and fuel pump hooked up on my 76 2.0 L and the engine cycles between reving and stalling when I hold the pedal down to get a fast idle. What do I need to be checking now?
tod914
post Jan 3 2013, 08:11 AM
On the top left side of the ECU, is your adjustment knob. Usually has a rubber cover on it the size of a dime. Regarding your trim pot, that's not factory. The PO might of had that hooked up to the cylinder head sensor on cyl #3. Check to make sure that head sensor is hooked up. That also can cause running issues. Hope that helps. At least your fuel pressure is good.
jdlmodelt   2.0l fuel injected engine surge starve cycle?   Jan 2 2013, 08:20 PM
tod914   Pinched line, clogged filter, filter on backwards,...   Jan 3 2013, 06:47 AM
jdlmodelt   Pinched line, clogged filter, filter on backwards...   Jan 3 2013, 07:14 AM
jdlmodelt   Pinched line, clogged filter, filter on backward...   Jan 3 2013, 07:22 AM
tod914   Double check your ignition wires on the coil as we...   Jan 3 2013, 06:58 AM
jdlmodelt   Double check your ignition wires on the coil as w...   Jan 3 2013, 07:11 AM
tod914   On the coil (I have a 74 2.0), green wire from con...   Jan 3 2013, 08:08 AM
tod914   On the top left side of the ECU, is your adjustmen...   Jan 3 2013, 08:11 AM
jdlmodelt   On the top left side of the ECU, is your adjustme...   Jan 3 2013, 08:32 AM
Spoke   Can you take some pics of this potentiometer you...   Jan 3 2013, 09:25 AM
jdlmodelt   Can you take some pics of this potentiometer you...   Jan 3 2013, 10:14 AM
Philip W.   Can you take some pics of this potentiometer you...   Jan 3 2013, 11:17 AM
jdlmodelt   [quote name='jdlmodelt' post='1795373' date='Jan ...   Jan 3 2013, 12:39 PM
jdlmodelt   Can you take some pics of this potentiometer you...   Jan 4 2013, 08:06 PM
Spoke   Can you rev it up to 2k, 3k and stay running? How...   Jan 3 2013, 10:32 AM
jdlmodelt   Can you rev it up to 2k, 3k and stay running? Ho...   Jan 3 2013, 11:14 AM
Philip W.   on the passenger side of the engine compartment - ...   Jan 3 2013, 01:25 PM
jdlmodelt   on the passenger side of the engine compartment -...   Jan 3 2013, 01:52 PM
brant   you mentioned the wire from the distributor earlie...   Jan 3 2013, 01:57 PM
jdlmodelt   you mentioned the wire from the distributor earli...   Jan 3 2013, 02:06 PM
r_towle   read http://members.rennlist.com/pbanders/DjetPar...   Jan 3 2013, 02:01 PM
Philip W.   read http://members.rennlist.com/pbanders/DjetPa...   Jan 3 2013, 02:07 PM
jdlmodelt   [quote name='r_towle' post='1795525' date='Jan 3 ...   Jan 3 2013, 02:19 PM
Spoke   Does LJET have an MPS? I thought it had a mass flo...   Jan 3 2013, 02:29 PM
Philip W.   Does LJET have an MPS? I thought it had a mass fl...   Jan 3 2013, 02:44 PM
Philip W.   duplicate post- darn phone! - bill you have a...   Jan 3 2013, 02:50 PM
tod914   Do you have your oil pressure switch plugged in? ...   Jan 3 2013, 02:29 PM
jdlmodelt   Do you have your oil pressure switch plugged in? ...   Jan 3 2013, 03:08 PM
r_towle   75/76 2.0 liter motor is Djet Fuel Injection. The...   Jan 3 2013, 03:35 PM
rhodyguy   reving and near stalling on its own accord is also...   Jan 3 2013, 04:13 PM
jdlmodelt   I'm reading thru all the troubleshooting that ...   Jan 3 2013, 08:53 PM
tod914   Two suggestions, one take photos of your engine ba...   Jan 4 2013, 11:25 AM
jdlmodelt   Two suggestions, one take photos of your engine b...   Jan 4 2013, 06:58 PM
jdlmodelt   thanks everyone for all of the hints to figure thi...   Jan 4 2013, 07:00 PM
- Lo-Fi Version Time is now: 26th April 2025 - 01:33 AM
