> 2.0l fuel injected engine surge starve cycle?
jdlmodelt
post Jan 2 2013, 08:20 PM
James D. Lane
I finally got the ignition and fuel pump hooked up on my 76 2.0 L and the engine cycles between reving and stalling when I hold the pedal down to get a fast idle. What do I need to be checking now?
Spoke
post Jan 3 2013, 09:25 AM
Jerry
Can you take some pics of this potentiometer you're talking about? There was a trim adjustment on the ECU but not one in the wiring harness. May have been some bandaid by the PO.
BTW, how is the normal idle? Is it smooth?
How does the engine run if you try to go to a high RPM like 2k, 3k?
Does it run good enough to drive it?
jdlmodelt
post Jan 3 2013, 10:14 AM
James D. Lane
QUOTE(Spoke @ Jan 3 2013, 08:25 AM) *
the idle is smooth but so low that it stalls out after 3-5 seconds. If I start it with not pedal and get it idling then try to give it some gentle pedal it immediately stalls out. So, I can't even get it out of the garage yet to try it out. I had it running enough last night with short idles to get the engine warm enough that coldness should not have been the issue. (IMG:style_emoticons/default/sad.gif)
DRPHIL914
post Jan 3 2013, 11:17 AM
Dr. Phil
QUOTE(jdlmodelt @ Jan 3 2013, 11:14 AM) *
i have a 75 2.0 and had a similar problem. if you are running really lean, you may have a surge cycle like you described. The POT you are talking about is most likely someone put there because the CHT was out of spec and they were increasing the resistance to fool the ECU so that you can adjust the richness. have you tested your MPS yet? a bad MPS will cause lots of these problems. running rich will cause a slower idle but make sure timing i s spot on first. check the ohm reading of your CHT, make sure it is the right one and that is specs out for your car. my car would start and stall when i first go it because it would flood out, it was a bad MPS, but a rebuilt MPS sent to me that was set too lean was causing the idle surge you have, and i had to increase the richness setting and was good to go. - look at your spark plugs- are the sooty , or lite from running hot/ it really sounds like you are flooding out. DO a vac check on the MPS first.
phil
jdlmodelt   2.0l fuel injected engine surge starve cycle?   Jan 2 2013, 08:20 PM
tod914   Pinched line, clogged filter, filter on backwards,...   Jan 3 2013, 06:47 AM
jdlmodelt   Pinched line, clogged filter, filter on backwards...   Jan 3 2013, 07:14 AM
jdlmodelt   Pinched line, clogged filter, filter on backward...   Jan 3 2013, 07:22 AM
tod914   Double check your ignition wires on the coil as we...   Jan 3 2013, 06:58 AM
jdlmodelt   Double check your ignition wires on the coil as w...   Jan 3 2013, 07:11 AM
tod914   On the coil (I have a 74 2.0), green wire from con...   Jan 3 2013, 08:08 AM
tod914   On the top left side of the ECU, is your adjustmen...   Jan 3 2013, 08:11 AM
jdlmodelt   On the top left side of the ECU, is your adjustme...   Jan 3 2013, 08:32 AM
Spoke   Can you take some pics of this potentiometer you...   Jan 3 2013, 09:25 AM
jdlmodelt   Can you take some pics of this potentiometer you...   Jan 3 2013, 10:14 AM
Philip W.   Can you take some pics of this potentiometer you...   Jan 3 2013, 11:17 AM
jdlmodelt   [quote name='jdlmodelt' post='1795373' date='Jan ...   Jan 3 2013, 12:39 PM
jdlmodelt   Can you take some pics of this potentiometer you...   Jan 4 2013, 08:06 PM
Spoke   Can you rev it up to 2k, 3k and stay running? How...   Jan 3 2013, 10:32 AM
jdlmodelt   Can you rev it up to 2k, 3k and stay running? Ho...   Jan 3 2013, 11:14 AM
Philip W.   on the passenger side of the engine compartment - ...   Jan 3 2013, 01:25 PM
jdlmodelt   on the passenger side of the engine compartment -...   Jan 3 2013, 01:52 PM
brant   you mentioned the wire from the distributor earlie...   Jan 3 2013, 01:57 PM
jdlmodelt   you mentioned the wire from the distributor earli...   Jan 3 2013, 02:06 PM
r_towle   read http://members.rennlist.com/pbanders/DjetPar...   Jan 3 2013, 02:01 PM
Philip W.   read http://members.rennlist.com/pbanders/DjetPa...   Jan 3 2013, 02:07 PM
jdlmodelt   [quote name='r_towle' post='1795525' date='Jan 3 ...   Jan 3 2013, 02:19 PM
Spoke   Does LJET have an MPS? I thought it had a mass flo...   Jan 3 2013, 02:29 PM
Philip W.   Does LJET have an MPS? I thought it had a mass fl...   Jan 3 2013, 02:44 PM
Philip W.   duplicate post- darn phone! - bill you have a...   Jan 3 2013, 02:50 PM
tod914   Do you have your oil pressure switch plugged in? ...   Jan 3 2013, 02:29 PM
jdlmodelt   Do you have your oil pressure switch plugged in? ...   Jan 3 2013, 03:08 PM
r_towle   75/76 2.0 liter motor is Djet Fuel Injection. The...   Jan 3 2013, 03:35 PM
rhodyguy   reving and near stalling on its own accord is also...   Jan 3 2013, 04:13 PM
jdlmodelt   I'm reading thru all the troubleshooting that ...   Jan 3 2013, 08:53 PM
tod914   Two suggestions, one take photos of your engine ba...   Jan 4 2013, 11:25 AM
jdlmodelt   Two suggestions, one take photos of your engine b...   Jan 4 2013, 06:58 PM
jdlmodelt   thanks everyone for all of the hints to figure thi...   Jan 4 2013, 07:00 PM
- Lo-Fi Version Time is now: 26th April 2025 - 01:28 AM
