> 2.0l fuel injected engine surge starve cycle?
jdlmodelt
post Jan 2 2013, 08:20 PM
James D. Lane
I finally got the ignition and fuel pump hooked up on my 76 2.0 L and the engine cycles between reving and stalling when I hold the pedal down to get a fast idle. What do I need to be checking now?
brant
post Jan 3 2013, 01:57 PM
you mentioned the wire from the distributor earlier in this thread.
that wire in a brown sheathing has another one of what your calling a rectangular tombstone plug end... it picks up the signal from the fuel injection points and tells the injectors when to open
without it no gas
often one of those 4 wires will brake, causing 1 bank to get gas the other bank not too
check that connection carefully.
the MPS, CHT, and Distributor fuel injection points are all Very important to the fuel injection system.
you may want to spend 4 hours reading the brad anders website that details all of the fuel injection componenets and how to test them.
jdlmodelt   2.0l fuel injected engine surge starve cycle?   Jan 2 2013, 08:20 PM
tod914   Pinched line, clogged filter, filter on backwards,...   Jan 3 2013, 06:47 AM
jdlmodelt   Pinched line, clogged filter, filter on backwards...   Jan 3 2013, 07:14 AM
jdlmodelt   Pinched line, clogged filter, filter on backward...   Jan 3 2013, 07:22 AM
tod914   Double check your ignition wires on the coil as we...   Jan 3 2013, 06:58 AM
jdlmodelt   Double check your ignition wires on the coil as w...   Jan 3 2013, 07:11 AM
tod914   On the coil (I have a 74 2.0), green wire from con...   Jan 3 2013, 08:08 AM
tod914   On the top left side of the ECU, is your adjustmen...   Jan 3 2013, 08:11 AM
jdlmodelt   On the top left side of the ECU, is your adjustme...   Jan 3 2013, 08:32 AM
Spoke   Can you take some pics of this potentiometer you...   Jan 3 2013, 09:25 AM
jdlmodelt   Can you take some pics of this potentiometer you...   Jan 3 2013, 10:14 AM
Philip W.   Can you take some pics of this potentiometer you...   Jan 3 2013, 11:17 AM
jdlmodelt   [quote name='jdlmodelt' post='1795373' date='Jan ...   Jan 3 2013, 12:39 PM
jdlmodelt   Can you take some pics of this potentiometer you...   Jan 4 2013, 08:06 PM
Spoke   Can you rev it up to 2k, 3k and stay running? How...   Jan 3 2013, 10:32 AM
jdlmodelt   Can you rev it up to 2k, 3k and stay running? Ho...   Jan 3 2013, 11:14 AM
Philip W.   on the passenger side of the engine compartment - ...   Jan 3 2013, 01:25 PM
jdlmodelt   on the passenger side of the engine compartment -...   Jan 3 2013, 01:52 PM
brant   you mentioned the wire from the distributor earlie...   Jan 3 2013, 01:57 PM
jdlmodelt   you mentioned the wire from the distributor earli...   Jan 3 2013, 02:06 PM
r_towle   read http://members.rennlist.com/pbanders/DjetPar...   Jan 3 2013, 02:01 PM
Philip W.   read http://members.rennlist.com/pbanders/DjetPa...   Jan 3 2013, 02:07 PM
jdlmodelt   [quote name='r_towle' post='1795525' date='Jan 3 ...   Jan 3 2013, 02:19 PM
Spoke   Does LJET have an MPS? I thought it had a mass flo...   Jan 3 2013, 02:29 PM
Philip W.   Does LJET have an MPS? I thought it had a mass fl...   Jan 3 2013, 02:44 PM
Philip W.   duplicate post- darn phone! - bill you have a...   Jan 3 2013, 02:50 PM
tod914   Do you have your oil pressure switch plugged in? ...   Jan 3 2013, 02:29 PM
jdlmodelt   Do you have your oil pressure switch plugged in? ...   Jan 3 2013, 03:08 PM
r_towle   75/76 2.0 liter motor is Djet Fuel Injection. The...   Jan 3 2013, 03:35 PM
rhodyguy   reving and near stalling on its own accord is also...   Jan 3 2013, 04:13 PM
jdlmodelt   I'm reading thru all the troubleshooting that ...   Jan 3 2013, 08:53 PM
tod914   Two suggestions, one take photos of your engine ba...   Jan 4 2013, 11:25 AM
jdlmodelt   Two suggestions, one take photos of your engine b...   Jan 4 2013, 06:58 PM
jdlmodelt   thanks everyone for all of the hints to figure thi...   Jan 4 2013, 07:00 PM
- Lo-Fi Version Time is now: 26th April 2025 - 01:25 AM
