> 2.0l fuel injected engine surge starve cycle?
jdlmodelt
post Jan 2 2013, 08:20 PM
James D. Lane
I finally got the ignition and fuel pump hooked up on my 76 2.0 L and the engine cycles between reving and stalling when I hold the pedal down to get a fast idle. What do I need to be checking now?
Spoke
post Jan 3 2013, 02:29 PM
Jerry
Does LJET have an MPS? I thought it had a mass flow sensor.
The car is a '76. This would've been LJET, correct?
jdlmodelt   2.0l fuel injected engine surge starve cycle?   Jan 2 2013, 08:20 PM
tod914   Pinched line, clogged filter, filter on backwards,...   Jan 3 2013, 06:47 AM
jdlmodelt   Pinched line, clogged filter, filter on backwards...   Jan 3 2013, 07:14 AM
jdlmodelt   Pinched line, clogged filter, filter on backward...   Jan 3 2013, 07:22 AM
tod914   Double check your ignition wires on the coil as we...   Jan 3 2013, 06:58 AM
jdlmodelt   Double check your ignition wires on the coil as w...   Jan 3 2013, 07:11 AM
tod914   On the coil (I have a 74 2.0), green wire from con...   Jan 3 2013, 08:08 AM
tod914   On the top left side of the ECU, is your adjustmen...   Jan 3 2013, 08:11 AM
jdlmodelt   On the top left side of the ECU, is your adjustme...   Jan 3 2013, 08:32 AM
Spoke   Can you take some pics of this potentiometer you...   Jan 3 2013, 09:25 AM
jdlmodelt   Can you take some pics of this potentiometer you...   Jan 3 2013, 10:14 AM
Philip W.   Can you take some pics of this potentiometer you...   Jan 3 2013, 11:17 AM
jdlmodelt   [quote name='jdlmodelt' post='1795373' date='Jan ...   Jan 3 2013, 12:39 PM
jdlmodelt   Can you take some pics of this potentiometer you...   Jan 4 2013, 08:06 PM
Spoke   Can you rev it up to 2k, 3k and stay running? How...   Jan 3 2013, 10:32 AM
jdlmodelt   Can you rev it up to 2k, 3k and stay running? Ho...   Jan 3 2013, 11:14 AM
Philip W.   on the passenger side of the engine compartment - ...   Jan 3 2013, 01:25 PM
jdlmodelt   on the passenger side of the engine compartment -...   Jan 3 2013, 01:52 PM
brant   you mentioned the wire from the distributor earlie...   Jan 3 2013, 01:57 PM
jdlmodelt   you mentioned the wire from the distributor earli...   Jan 3 2013, 02:06 PM
r_towle   read http://members.rennlist.com/pbanders/DjetPar...   Jan 3 2013, 02:01 PM
Philip W.   read http://members.rennlist.com/pbanders/DjetPa...   Jan 3 2013, 02:07 PM
jdlmodelt   [quote name='r_towle' post='1795525' date='Jan 3 ...   Jan 3 2013, 02:19 PM
Spoke   Does LJET have an MPS? I thought it had a mass flo...   Jan 3 2013, 02:29 PM
Philip W.   Does LJET have an MPS? I thought it had a mass fl...   Jan 3 2013, 02:44 PM
Philip W.   duplicate post- darn phone! - bill you have a...   Jan 3 2013, 02:50 PM
tod914   Do you have your oil pressure switch plugged in? ...   Jan 3 2013, 02:29 PM
jdlmodelt   Do you have your oil pressure switch plugged in? ...   Jan 3 2013, 03:08 PM
r_towle   75/76 2.0 liter motor is Djet Fuel Injection. The...   Jan 3 2013, 03:35 PM
rhodyguy   reving and near stalling on its own accord is also...   Jan 3 2013, 04:13 PM
jdlmodelt   I'm reading thru all the troubleshooting that ...   Jan 3 2013, 08:53 PM
tod914   Two suggestions, one take photos of your engine ba...   Jan 4 2013, 11:25 AM
jdlmodelt   Two suggestions, one take photos of your engine b...   Jan 4 2013, 06:58 PM
jdlmodelt   thanks everyone for all of the hints to figure thi...   Jan 4 2013, 07:00 PM
- Lo-Fi Version Time is now: 26th April 2025 - 01:25 AM
