jdlmodelt |
James D. Lane ![]() ![]() Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region ![]() |
I finally got the ignition and fuel pump hooked up on my 76 2.0 L and the engine cycles between reving and stalling when I hold the pedal down to get a fast idle. What do I need to be checking now?
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
Two suggestions, one take photos of your engine bay and post them.
Second suggestion which is what I would do, is to very carefully remove your FI harness. Then label each connector on it with tape and mark it exactly as shown in the diagram I sent you; A, B, C, D etc.. Then, find each associate sensor, etc. and mark that area with tape and label it; A B C D according to the diagram; example "I" = coldstart valve. Then use the diagram as a check list as each piece is connected. That should help in getting it installed properly and minimize any connectors in question. Otherwise it looks like a birds nest of wires. Hope that helps. |
Lo-Fi Version | Time is now: 26th April 2025 - 01:22 AM |
