> Dashboards are hard!, --- Let's talk vacuum bagging
Bob L.
post Jan 6 2013, 12:55 PM
Hello World, Happy new year!
I have removed the dashboard from the car and have tried to recover the dash by hand using a heat gun and brute force stretching//pushing/cramming etc.
As much as it was a PITA, it was coming along pretty well.
Both times!
The first time I realized the glue wouldn't hold up in the heat. The second time I realized I want to use a Uv protected vinyl. Generally marine vinyl. I had no idea about the vinyl I was using, so off it came. I found some that will hold up well and is much stretchier than what I what I had been using. Awaiting samples.
Now, I have seen a lot about Vacuum bagging/pressing and want to try it on my dashboard. I think it would work well at normal temps with the stretchier vinyl and the right glue. (Weldwood)
So, I'm wondering if anyone has any experience they would like to share.
I have a vacuum pump but no bag yet. I've found a few options. They're
expensive!
I feel that the vacuum bagging will show the cracks much more than hand fitting so I want to fill them better. Is RTV the best thing to use? Maybe CA glue?
Advice and suggestions welcome.
TIA.
Bob.
Bartlett 914
post Jan 7 2013, 09:43 AM
Good thread. I would just add that I see several comments about using 5 minute epoxy. 5 minute epoxy is "thermal Plastic" 12 or 24 hour epoxys are usually "Thermal setting" The thermal plastic epoxy will soften with heat. The thermal setting will set faster with heat and is not as easily effected with heat. The dash will get hot in the sun.
Bob L.   Dashboards are hard!   Jan 6 2013, 12:55 PM
KaptKaos   :popcorn:   Jan 6 2013, 01:05 PM
914Sixer   Back in the 80's when I worked for Orig-Quip p...   Jan 6 2013, 01:05 PM
Gint   Interesting project. I look forward to seeing the...   Jan 6 2013, 01:06 PM
Jeff Hail   Any imperfections present (crease, wrinkles etc) w...   Jan 6 2013, 01:19 PM
stugray   You can vacuum bag with industrial strength saran-...   Jan 6 2013, 01:49 PM
nomore9one4   I dont know how vacuum bagging works but maybe you...   Jan 6 2013, 01:49 PM
Dr Evil   Very thin foam is a nice way to cover the cracks. ...   Jan 6 2013, 02:18 PM
bulitt   Very thin foam is a nice way to cover the cracks....   Jan 7 2013, 06:32 AM
euro911   :popcorn: When I read the title to this thread, I...   Jan 6 2013, 03:02 PM
Bob L.   stugray Posted Jan 6 2013, 01:49 PM "You ...   Jan 6 2013, 03:49 PM
Bob L.   Could "Plasti Dip" be used to fill the c...   Jan 6 2013, 05:38 PM
nomore9one4   Never tried the plasti dip.. For a deep cracks I ...   Jan 6 2013, 06:09 PM
Bob L.   Never tried the plasti dip.. For a deep cracks I...   Jan 6 2013, 06:44 PM
nomore9one4   Never tried the plasti dip.. For a deep cracks ...   Jan 6 2013, 07:40 PM
bulitt   I think there was a member that filled the cracks ...   Jan 6 2013, 07:19 PM
Dr Evil   Spray foam would be the best for deep cracks, but ...   Jan 6 2013, 07:43 PM
nomore9one4   Spray foam would be the best for deep cracks, but...   Jan 6 2013, 07:47 PM
tracks914   I filled the cracks in my dash with 3 minute epoxy...   Jan 6 2013, 07:46 PM
Bob L.   The cracks aren't deep. Mostly just through th...   Jan 6 2013, 08:40 PM
Dr Evil   1/8" from a upholstery shop will work.   Jan 6 2013, 08:45 PM
nomore9one4   I may be wrong, but didnt craig at "camp914...   Jan 6 2013, 09:04 PM
boxstr   Give me a call and I can give you some ideas on ho...   Jan 6 2013, 09:35 PM
moparrob   The epoxy idea is a good start for the cracks. You...   Jan 7 2013, 01:51 AM
76-914   The epoxy idea is a good start for the cracks. Yo...   Jan 7 2013, 10:02 AM
euro911   ... Bob, if you go this route PM me. I have some l...   Jan 8 2013, 01:03 AM
Phoenix-MN   When I modified a 911 dash for my project I used t...   Jan 7 2013, 06:55 AM
Woody   You can vacuum bag with industrial strength saran...   Jan 7 2013, 07:38 AM
ruby914   You can vacuum bag with industrial strength sara...   Jan 8 2013, 06:12 PM
Bartlett 914   :popcorn: Good thread. I would just add that I s...   Jan 7 2013, 09:43 AM
Bob L.   Thanks for some good ideas. I'll probably do t...   Jan 8 2013, 12:14 AM
nathansnathan   Thanks for some good ideas. I'll probably do ...   Jan 8 2013, 05:37 PM
Valy   I used baking soda and superglue on several dash r...   Jan 8 2013, 05:06 PM
charliew   I have done some diy car interiors, mostly when I ...   Jan 8 2013, 06:00 PM
tracks914   BTW I did cut back the edges too when i used epoxy...   Jan 9 2013, 01:02 PM
charliew   The only thing I know about cf is my son's sti...   Jan 9 2013, 01:57 PM
Bob L.   www.diyupholsterysupply.com All sport marine Vinyl...   Jan 9 2013, 02:35 PM
ruby914   www.diyupholsterysupply.com All sport marine Viny...   Jan 10 2013, 03:48 AM
charliew   I have thought about this and and I think the fill...   Jan 9 2013, 03:28 PM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 08:55 PM
