last337 |
Member ![]() ![]() Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None ![]() |
Hello everyone! I got my new EMPI 40s on yesterday and I have been going through the adjustment all day today. It has been a long time since I have messed with carbs and Im not sure if I am doing this correct.
Initially I got my linkages all set up and correct with the speed screw at about 1 turn in. I have all the air bleed screws all lightly seated and mixture screws about 1 1/2 turns out. At this point it is very rich but runs well at an idle of about 900 and actually comes up really nice but is smoking and even spitting out fuel from exhaust. I figured at this point I could begin going in 1/4 turn at a time on each mixture screw to the point the engine starts to run rough then back a 1/4 turn. I did this on all and it was still smoking badly. I havent set timing or anything like that but I would assume the only electrical issue (am I wrong?) that could cause rich conditions at idle would be a fouled plug but it is running smooth and not as if it is missing with a fouled plug. I am wondering if maybe I should go another half turn on the speed screw then see if I can go in further with the mixture screws. Is there anything I can do with the air bleed to adjust this? I thought they were only adjusted for syncing and not for a rich condition. The vendor I got them from claims they have the following jets: 52 idle jets 115 main jets 200 air jets 28mm venturi 550 EX. pump jets 50 accelpump jets F11 emulsion tubes Am I oversized with that I have in there now? I have been reading the following link to troubleshoot and it says if I am over 1 1/2 turns in on mixture then my jets are too big. The problem is that I cant get it to run at under 1 1/2 turns on mixture. However, maybe I should try another half turn on speed screws? Any help is greatly appreciated (IMG:style_emoticons/default/biggrin.gif) |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,102 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
opening a air bleed screw allows air to enter that venturi beneath the throttle plate at low engine speeds and be can used to equalize the air flow thru the carbs during low speed idle. so when you closed by-pass screw, you richened things up. you'll need to confirm the sizes of venturis, the idle jets, [main gas jets, air corrector jets, and the emulsion tubes. these are all part of the main jet stack].
for 40s in stock form you should see a # on the top edge of a venturi. you might see 28. i wouldn't bet that your facet puts out a consistent 3.5#. |
last337 |
opening a air bleed screw allows air to enter that venturi beneath the throttle plate at low engine speeds and be can used to equalize the air flow thru the carbs during low speed idle. so when you closed by-pass screw, you richened things up. you'll need to confirm the sizes of venturis, the idle jets, [main gas jets, air corrector jets, and the emulsion tubes. these are all part of the main jet stack]. for 40s in stock form you should see a # on the top edge of a venturi. you might see 28. i wouldn't bet that your facet puts out a consistent 3.5#. So, should I open the bypass screws a bit to lean things out? I unfortunately do not have access to a dyno or a exhaust gas analyzer. Is it necessary for basic tuning or are there other ways to tell when I am going too lean? Wont the carb start popping when it leans out or is that when it is too rich? I just edited this after reading the following link It seems like what I am experiencing is most likely either a problem of poor ignition or a problem with my jets. If it isnt smoking at idle with everything okay I would assume my idle jets are fine? If it smokes only when accelerating where should I start? I suppose I can give CB a call at that point. Also, I still dont know if I have a stock cam or not. Is there any way to tell other than opening engine up? Id love to know what is in there. The stock jets are as follows based on vendors doc's but you are right I should double-check if still have problems. 52 idle jets 115 main jets 200 air jets 28mm venturi 550 EX. pump jets 50 accelpump jets F11 emulsion tubes |
Lo-Fi Version | Time is now: 20th June 2024 - 05:44 AM |
