Dashboards are hard!, --- Let's talk vacuum bagging |
Bob L. |
Jan 6 2013, 12:55 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Hello World, Happy new year!
I have removed the dashboard from the car and have tried to recover the dash by hand using a heat gun and brute force stretching//pushing/cramming etc. As much as it was a PITA, it was coming along pretty well. Both times! The first time I realized the glue wouldn't hold up in the heat. The second time I realized I want to use a Uv protected vinyl. Generally marine vinyl. I had no idea about the vinyl I was using, so off it came. I found some that will hold up well and is much stretchier than what I what I had been using. Awaiting samples. Now, I have seen a lot about Vacuum bagging/pressing and want to try it on my dashboard. I think it would work well at normal temps with the stretchier vinyl and the right glue. (Weldwood) So, I'm wondering if anyone has any experience they would like to share. I have a vacuum pump but no bag yet. I've found a few options. They're expensive! I feel that the vacuum bagging will show the cracks much more than hand fitting so I want to fill them better. Is RTV the best thing to use? Maybe CA glue? Advice and suggestions welcome. TIA. Bob. |
moparrob |
Jan 7 2013, 01:51 AM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
The epoxy idea is a good start for the cracks. You need to add a sandable filler to it, though, to ease in the shaping of the finished product. The best product is called microballoons and we used to use it in model making. You add it to the epoxy and it makes it easier to sand.
Link to microballoons |
76-914 |
Jan 7 2013, 10:02 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,652 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The epoxy idea is a good start for the cracks. You need to add a sandable filler to it, though, to ease in the shaping of the finished product. The best product is called microballoons and we used to use it in model making. You add it to the epoxy and it makes it easier to sand. Link to microballoons Bob, if you go this route PM me. I have some leftover micro balloons from my aircraft days. |
euro911 |
Jan 8 2013, 01:03 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
... I hope they're safer than those big balloonsBob, if you go this route PM me. I have some leftover micro balloons from my aircraft days. (IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 6th January 2025 - 09:15 PM |
