> Rick - I need your help, chassis twist
TravisNeff
post Mar 17 2012, 10:20 PM
A few years ago I got a new welder, I welded everthing in site... Needless to say I never understood shrinkage.
I installed an Engman kit and not only did I rosette weld the kit in, I fully stiched the whole thing. The end result, a stiff chassis - but a bent tub.
My door gaps are totally fuquered. My passenger rear fender was replaced and they must have welded the front, then the back and I have a weird bubble in my fender well. So not everthing is the same.. My passenger side gap has been messed up since I got the car, huge gap at the back of the door.
Here's my measurements, not to be reconciled with the factor charts too much, I am sure I am measuring from different dimensions than that. Anyways my measurements are from the same spots side to side
Targa opening D 62.7, P 63.5 CM
Latch to hinge D 110.5, P 110.5 CM
Diag mid latch plate to top of targa D 109.4, P 108.4
Front bulkead to targa, D 42.6, P 141.5
My guess is:
the passenger cowl fell in, so did the drivers side
The drivers targa fell in, passenger stayed staticd (lots of welding on the e-brake area)
Pics to follow....
sofi2t81
post Mar 23 2012, 11:33 AM
Region Association: Germany
Good to follow that thread.
I have the problem that the PO messed up my passenger door gap when restoring the hell hole. He welded in the inner wheel house without supporting the longs, so my door gap is 1mm at the top.
My plan is to but the car on jack stands. Push the door gap open like you did and then weld in the Engman kit with little heat as possible. (IMG:style_emoticons/default/welder.gif)
Do you think that would work, or do I have to cut the longs? (I don’t like that idea (IMG:style_emoticons/default/unsure.gif) )
Peter
rick 918-S
post Mar 23 2012, 12:10 PM
Hey nice rack! -Celette
QUOTE(sofi2t81 @ Mar 23 2012, 12:33 PM) *
Peter
If there was no chassis stiffening done yet you should be able to move the gap. Once there, be sure to brace it before welding. Don't forget to check the targa top opening as you go.
jdlmodelt
post Jan 8 2013, 08:20 PM
James D. Lane
QUOTE(rick 918-S @ Mar 23 2012, 11:10 AM) *
Peter
Do I understand that to mean that if there was no chassis stiffening done then there is no cutting to do...just put the power jack in and straighten?
Travis Neff   Rick - I need your help   Mar 17 2012, 10:20 PM
Travis Neff   Here is a post from a while back with a similar si...   Mar 17 2012, 10:21 PM
Travis Neff   asdf   Mar 17 2012, 10:50 PM
Travis Neff   asdf   Mar 17 2012, 10:51 PM
Travis Neff   driver side rear   Mar 17 2012, 10:56 PM
Travis Neff   So the front cowl has definately fell in. The rea...   Mar 17 2012, 10:57 PM
rick 918-S   Hey Travis, Just wanted to let you know I saw this...   Mar 18 2012, 12:01 PM
jmill   Racine, WI is a little closer than AZ but this is ...   Mar 18 2012, 06:31 PM
Dr Evil   Dont show pics of Rick. He aint that pretty :) :po...   Mar 18 2012, 07:35 PM
rick 918-S   Dont show pics of Rick. He aint that pretty :) :p...   Mar 18 2012, 09:11 PM
MoveQik   Travis, I'll be over in 5. We'll have it ...   Mar 18 2012, 09:13 PM
Travis Neff   :smash: giddyup! lol Travis, I'll be ov...   Mar 18 2012, 09:20 PM
Travis Neff   My plan is to cut through the stiffening kit at th...   Mar 18 2012, 09:23 PM
rick 918-S   My plan is to cut through the stiffening kit at t...   Mar 18 2012, 09:27 PM
Travis Neff   So I will make my cuts here in the front   Mar 18 2012, 09:41 PM
rick 918-S   Show me the stiffeners. I would likely cut the sti...   Mar 18 2012, 09:50 PM
Eric_Shea   That is the stiffener...   Mar 18 2012, 09:53 PM
Travis Neff   LOL, you're looking right at them. i did my b...   Mar 18 2012, 09:58 PM
rick 918-S   LOL, you're looking right at them. i did my ...   Mar 18 2012, 10:02 PM
Travis Neff   Rear catches are out, front quarter windows & ...   Mar 18 2012, 10:59 PM
rick 918-S   Rear catches are out, front quarter windows ...   Mar 18 2012, 11:16 PM
FourBlades   I'd like to see a lot of pictures of how this ...   Mar 19 2012, 08:05 AM
Travis Neff   I will be documenting this all the way through, go...   Mar 19 2012, 08:57 AM
Travis Neff   I did my cuts like I showed you before, only cutti...   Mar 19 2012, 07:38 PM
Travis Neff   the car on jackstands, notice that i have the jack...   Mar 19 2012, 09:11 PM
Travis Neff   here's how i was positioning the porta power   Mar 19 2012, 09:12 PM
Travis Neff   here's the gaps after the push, looking a lot ...   Mar 19 2012, 09:14 PM
Travis Neff   tomorrow i will push back the driver's side of...   Mar 19 2012, 09:15 PM
76-914   :popcorn:   Mar 19 2012, 09:54 PM
rick 918-S   Good idea with the stands. Be sure to check your t...   Mar 19 2012, 10:26 PM
Travis Neff   a couple days ago i pushed out the drivers front c...   Mar 21 2012, 09:31 PM
Travis Neff   and a before pic - just for comparison. the drive...   Mar 21 2012, 09:32 PM
MoveQik   Looks good Travis. We leave at 1:30 tomorrow so h...   Mar 22 2012, 08:01 AM
Travis Neff   I am trying, but I am not holding my breath   Mar 22 2012, 08:42 AM
rick 918-S   Looking good Travis!   Mar 22 2012, 09:05 AM
sofi2t81   Good to follow that thread. I have the problem tha...   Mar 23 2012, 11:33 AM
rick 918-S   Good to follow that thread. I have the problem th...   Mar 23 2012, 12:10 PM
jdlmodelt   Good to follow that thread. I have the problem t...   Jan 8 2013, 08:20 PM
Travis Neff   Dont cut your longs!!!! I just cu...   Mar 23 2012, 12:09 PM
Travis Neff   Show us a pic of where you are at   Mar 23 2012, 12:43 PM
rick 918-S   Show us a pic of where you are at :agree: :tt...   Mar 23 2012, 10:52 PM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 17th January 2025 - 07:46 AM
