Dashboards are hard!, --- Let's talk vacuum bagging |
Bob L. |
Jan 6 2013, 12:55 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Hello World, Happy new year!
I have removed the dashboard from the car and have tried to recover the dash by hand using a heat gun and brute force stretching//pushing/cramming etc. As much as it was a PITA, it was coming along pretty well. Both times! The first time I realized the glue wouldn't hold up in the heat. The second time I realized I want to use a Uv protected vinyl. Generally marine vinyl. I had no idea about the vinyl I was using, so off it came. I found some that will hold up well and is much stretchier than what I what I had been using. Awaiting samples. Now, I have seen a lot about Vacuum bagging/pressing and want to try it on my dashboard. I think it would work well at normal temps with the stretchier vinyl and the right glue. (Weldwood) So, I'm wondering if anyone has any experience they would like to share. I have a vacuum pump but no bag yet. I've found a few options. They're expensive! I feel that the vacuum bagging will show the cracks much more than hand fitting so I want to fill them better. Is RTV the best thing to use? Maybe CA glue? Advice and suggestions welcome. TIA. Bob. |
tracks914 |
Jan 9 2013, 01:02 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
BTW I did cut back the edges too when i used epoxy.
Lo-Fi Version | Time is now: 6th January 2025 - 09:07 PM |
